Literature Offers
05/13/2002
Cooling and drying
Solutions to industrial cooling, drying, conveying, blowoff, cleaning, and static electricity problems are offered in a 96-p technical guide, which features technical explanations, performance data, photos, and drawings for each product.
Exair Corporation
exair.com
Write 316 on PE card
Gas boosters
Accessories for liquid pumps, gas boosters, and air amplifiers are presented, including air pilot switches, high pressure relief valves, pump cycle counters, air receiver tanks, and air control packages. The accessories are ideal for use with MAXIMATOR products.
MAXPRO TECHNOLOGIES
maxprotech.com
Write 317 on PE card
Tools and equipment
A Master Sourcebook for 2002 features thousands of products throughout the 316-p catalog. Tools kits, carts and cases, test equipment, hand and power tools, and wire/cable and fiber optics are among the items offered.
Jensen Tools
jensentools.com
Write 318 on PE card
Pressure and flow
Controlcat New Horizons in Pressure, Flow & Everything Else covers a variety of USA-made products, including conductivity and dissolved oxygen meters, controllers and transmitters, flow meters, signal conditioners, and switches. Forty-eight Dilbert cartoons are contained within the catalog.
Omega Engineering, Inc.
omega.com
Write 319 on PE card
Enclosures
The benefits and features of DiamondShield electrical enclosures are detailed in a brochure. The 10-product enclosure family is made of cost-effective fiberglass and is available in 150 configurations.
Stahlin Non-Metallic Enclosures
stahlin.com
Write 320 on PE card
Exhaust systems
A line of corrosion-resistant polyvinyl chloride, chlorinated polyvinyl chloride, and polypropylene fume exhaust systems and duct fittings is highlighted in a 28-product brochure. Factory Mutual and Underwriter Laboratories data are included.
PLASTINETICS
plastinetics.com
Write 321 on PE card
Load cells
Load Cell Guide #14 is a comprehensive catalog of strain gauge technology and features a large selection of load cells, weigh modules, sensors, and scale accessories. More than 30,000 in-stock products are available with same-day shipping.
Rice Lake Weighing Systems
rlws.com
Write 322 on PE card
Sensors
This catalog discusses a line of AC- and DC-operated linear and rotary position sensors and support electronics and offers easy reference with photos and specifications.
Macro Sensors
macrosensors.com
Write 323 on PE card
Pumps
Guide to high-pressure, high-volume industrial pumps focuses on the Hydra-Cell D-15 and D-17 series and discusses product features, specifications, ordering information, and application examples.
Hydra-Cell Industrial Pumps Wanner Engineering, Inc.
hydra-cell.com
Write 324 on PE card
Roof systems
A package of literature dedicated to SPF Roof Systems is available with information on design, components, applications, installation, and case histories. SPF roofs are used for both new construction and re-roofing projects.
BASF Corporation
basf.com
Write 325 on PE card
Roofs
A 2002 modified bitumen roofing catalog takes a look at a complete line of engineered systems, including granule-surfaced Paradiene and foil-faced Veral systems. The Siplast Certificate of Analysis Program is also explained in the literature.
Siplast/Icopal
siplast.com
Write 326 on PE card
Component fastening
A 96-p catalog makes fastening rotating components to shafts easier. Fairloc is designed to solve phasing, timing, positioning, and frequent removal problems that other methods can't properly handle.
Stock Drive Products/Sterling Instrument
sdp-si.com
Write 327 on PE card
Gas monitoring
The 2002 Haloguard Refrigerant Gas Monitor Product Guide instrument and accessory catalog gives descriptions and specifications for models that meet a range of monitoring requirements, including stringent refrigerant gas conservation and basic safety applications.
Thermal Gas Systems
thermalgas.com
Write 328 on PE card
Tools
Photographs, descriptions, and specifications for a complete line of Wright tools are contained in a 75th anniversary product catalog. Thirty additional pages of new products are featured in the 2002 version.
Wright Tool
wrighttool.com
Write 329 on PE card
Vacuum generators
A new version of the single and multi-venturi vacuum generator catalog includes a technical engineering section and an accessory section. Gast venturi vacuum generators have flow ranges from .2 cfm to 158 cfm and maximum vacuum from 7.5 to 27'' Hg.
Gast Manufacturing, Inc.
gastmfg.com
Write 330 on PE card
Commerical products
The 2002 Commercial Products Catalog provides information and specifications on roof scuttles, automatic fire vents, floor, vault and sidewalk doors, and LadderUP safety posts.
Bilco Company
bilco.com
Write 331 on PE card
Lubricaants
A complete package of industrial lubricants and services known as the Dow Corning Fluid Consolidation Program is described in a 4-p brochure. The program aims to reduce maintenance costs and extend equipment life.
Dow Corning
molykote.com\iam
Write 332 on PE card
March 2018
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
