Literature Offers
08/08/2002
Pavement maintenance
A pavement maintenance products catalog features a variety of asphalt and concrete coatings, crack sealants, line striping, marking and stenciling products, recreational color surfacing, tools, and safety supplies. The catalog is designed to help those responsible for maintaining parking lots and driveways with current projects and budgeting for future needs.
Maintenance, Inc.
maintinc.com
Write 316 on PE card
Bolting solutions
"Solutions to Bolting Problems" contains technical information on mechanical stud/bolt tensioners, including high temperature designs, updated installation and removal procedures, and several application examples. Products retrofit existing nuts and bolts and require only hand torque wrenches to tension bolts.
Superbolt
superbolt.com
Write 317 on PE card
Industrial interconnect
Terminal blocks and related products are the focus of a 96-p catalog with separate sections on pluggable terminal blocks and headers, fixed terminal blocks, interface modules, fixed and pluggable spring clamp blocks, screw barrier edgecard connectors, DIN rail-mount terminal blocks, and cable assemblies.
PCD, Inc.
pcdinc.com
Write 318 on PE card
Tubing
Eight pages are dedicated to a full range of precision fluoroplastic tubing, including convoluted and corrugated products. Tubing can be manufactured from PTFE, FEP, PFA, ETFE, ECTFE, MFA, THV, Radiopaque, PEEK, Ultem PEI, and conductive materials.
TexLoc, Ltd.
texloc.com
Write 319 on PE card
Casters and wheels
A complete line of casters and wheels, including new product lines with increased load capacity on many models, is discussed in a 108-p, full-color catalog. Foot activated swivel locks and shopping cart casters are among the new offerings.
Colson Caster Corporation
colsoncaster.com
Write 320 on PE card
Anchors
A catalog includes comprehensive information on adhesives, mechanical anchors, powder actuated fastening systems and carbide drill bits, and chisels. Product descriptions and expanded technical data are compiled in an easy-to-read format.
Simpson Strong-Tie
strongtie.com
Write 321 on PE card
Flow instrumentation
A catalog features Flow-Mon USA, a new monitor line for flow rate indication in liquid, air, and gas applications that offers a choice between a variable area piston and a vane style monitor with a modular design for easy field installation and service.
Sure Flow Products
sureflowproducts.com
Write 322 on PE card
Power generation
PowerCommand medium-voltage digital paralleling systems and switchgear for onsite power applications are covered in a brochure. Features include a touchscreen with expanded operational and diagnostic information for system operators, a graphic display with 21 generator parameters in digital or analog format, and a one-line diagram permitting operators to view the entire system at a glance.
Cummins Power Generation
cumminspowergeneration.com
Write 323 on PE card
Sorbents
Sorbent pads, booms, rolls, socs, and rugs are among the 120 products showcased. Also included are 22 new products for a variety of markets and applications. More than 50% of the items in the catalog are less than 5-yrs old.
Sorbent Products Company
sorbentproducts.com
Write 324 on PE card
Conveyors
Color photos of conveyors with explanations of the strengths and variations between the different series, in-depth information on all new belts, motors, and accessories, and a layout designed to walk customers through the phases of their order are highlights of the catalog.
Dorner Manufacturing Corporation
dorner.com
Write 325 on PE card
Temperature measurement
Portable temperature measurement systems are explored in a catalog. A Heat Prober system can interpret the temperature sensed, provide digital display output, and allow measurement options.
Wahl Instruments, Inc.
instrumentationgroup.com
Write 326 on PE card
Operating elements
A catalog features a line of metallic operating elements, including more than 100 products in steel, stainless steel, and aluminum. Most are available in a wide range of sizes.
Elesa U.S.A. Corp.
elesausa.com
Write 327 on PE card
Management systems
A product catalog CD highlights the TALON Open Protocol Building Management System, MS1800 Building Management System, and Siemens HVAC control products, including valves, actuators, and sensors. The user-friendly CD also contains keyword and part number search functions.
Siemens Building Technologies, Inc.
staefa.com
Write 328 on PE card
Air filters
A 4-p bulletin details a line of thin bed adsorptive air filtration products, including OdorGuard granular activated carbon filters for use in HVAC systems. Appliance and air cleaner filters and carbon and adsorbent filled trays are also discussed.
D-Mark, Inc.
dmarkinc.com
Write 329 on PE card
Maintenance management
Graphic illustrations of sample screen captures give readers an indication of the layout and design of TabWare, a maintenance management system. The brochure discusses the customer benefits of using Tab Ware as a continuous maintenance improvement tool.
AssetPoint
tabware.com
Write 330 on PE card
Electrical connectors
A catalog provides enhancements such as a pictorial index with a reference to the page number for a specific series of parts. The product page layout has been refined to include features and benefits as well as options available for a specific category of parts.
UTILCO, a division of ILSCO
utilco.com
Write 331 on PE card
Coating measurement
A flyer describes how the FISCHERSCOPE X-RAY XDVM-
Fischer Technology
fischer-technology.com
Write 332 on PE card
Silicone rubber
Silicone rubber products are highlighted, including solid rubber, sponge rubber, F-12 foam, and Strip-N-Stick tape.
Saint-Gobain Performance Plastics
plastics.saint-gobain.com
Write 333 on PE card
Heat exchangers
A CD catalog features a complete line of brazed heat exchangers and includes information about the operation of the BHE, heat exchanger sizes available with dimensions, specifications and connections, suitable applications for each BHE model, drawings for each model, and a cross-reference database.
Alfa Laval
alfalaval.com
Write 334 on PE card
Lubrication
A 132-p catalog of lubrication equipment and supplies is an easy-to-follow guide to pumping systems, grease guns, auto grease systems, grease fittings, meters, reels, and MRO lube supplies. Performance charts, installation tips, and complete ordering information are included.
Alemite
alemite.com
Write 335 on PE card
Power supplies
Arc welding power supplies and accessories are the theme of a 48-p catalog that uses an easy-to-grasp design, putting key details at the same spot on each page. A product selection guide, used in conjunction with the contents index, quickly guides users to critical buying decision information.
Thermal Arc
thermalarc.com
Write 336 on PE card
March 2018
Jan/Feb 2018
December 2017
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
