How compressed air systems work: A guide to components and efficiency
Compressed air is easy to overlook, but it is one of the most important utilities in a plant. This must-read guide cuts to the core of compressed air systems –– including how they work, their components and efficiency.
Compressed Air Insights
  • A compressed air system includes a compressor, air receiver, dryer, filters, drains, regulators, piping, controls and monitoring equipment.
  • The three main types of compressors are: rotary screw compressors, reciprocating compressors and centrifugal compressors.
  • Steps can be taken to improve compressed air efficiency instead of replacing the entire system.
Compressed air is easy to overlook; that is, until it stops working.
In manufacturing and industrial facilities, compressed air powers pneumatic tools, operates automated equipment, moves materials, supports packaging processes and plays a role in everything from metal fabrication to food processing. It’s often considered a utility, much like electricity or water, but there is one important difference: compressed air must be manufactured before it can be used.
That means there is quite a bit happening between the moment atmospheric air enters a compressor and the moment it reaches a production machine.
A complete compressed air system must generate air, treat it, store it and distribute it where it is needed. If any part of that system is poorly designed, the entire operation can suffer.
This guide looks at how compressed air systems work, the major components involved, how to select the right equipment, and what manufacturers can do to improve reliability and efficiency.
What Is a Compressed Air System?
A compressed air system is a network of equipment used to generate, treat, store and distribute compressed air.
The process sounds simple: take atmospheric air, compress it and send it to equipment that needs it. In practice, however, a reliable industrial system involves considerably more than a compressor sitting in the corner of a building.
A typical system can include a compressor, air receiver, dryer, filters, drains, regulators, piping, controls and monitoring equipment. Depending on the application, additional air treatment or specialized equipment may also be required.
Importantly, these components work together. A compressor can be perfectly sized and still fail to deliver the expected performance if the piping is undersized, the dryer is inadequate or pressure is being lost somewhere in the system.
In other words, the compressor may be the star of the show, but it has a large supporting cast.
How Does a Compressed Air System Work?
The process begins with atmospheric air.
A compressor draws air into the machine and reduces its volume, increasing its pressure. Different compressor technologies accomplish this in different ways, including rotary screw, reciprocating piston and centrifugal compression.
Once the air has been compressed, it is typically hot and may contain moisture, oil or other contaminants. That means it usually needs to be treated before it reaches the equipment using it.
A simplified compressed air system looks something like this:
Atmospheric air → Compression → Air treatment → Storage → Distribution → Point of use
The exact configuration varies depending on the application, but the basic objective remains the same: provide the right amount of clean, dry compressed air at the right pressure and flow.
The Compressor: The Heart of the System
The compressor is usually the first piece of equipment people think about when they hear “compressed air system.” It is certainly important but choosing one shouldn’t come down to horsepower alone.
The compressor must match the facility’s actual requirements, including airflow, pressure, operating hours and demand patterns. Ambient conditions, air quality requirements and future production growth can also influence the selection.
There are several major compressor technologies.
Rotary Screw Compressors
Rotary screw compressors are widely used in industrial applications and are designed to provide a continuous supply of compressed air. They can be particularly well-suited to facilities with relatively consistent demand.
They are available in both fixed-speed and variable-speed configurations, giving facilities options for managing changing air requirements.
Reciprocating Compressors
Reciprocating compressors use pistons to compress air. They can be a good fit for applications with intermittent demand, smaller air requirements or specific pressure needs.
Centrifugal Compressors
Centrifugal compressors use high-speed rotating impellers to increase air pressure and are generally used in larger industrial applications requiring substantial volumes of compressed air.
There is no universal “best” compressor technology. The right choice depends on the application, operating conditions and demand profile.
Pressure and Flow: Two Numbers That Matter
Two of the most important specifications in a compressed air system are pressure and flow.
Flow describes how much compressed air is available, commonly measured in cubic feet per minute (CFM). Pressure describes the force of the compressed air and is commonly measured in pounds per square inch gauge (PSIG).
They work together, but they are not the same thing.
A facility may have enough compressor capacity but still experience poor performance if pressure drops before the air reaches the point of use. On the other hand, operating a system at a higher pressure than necessary can increase energy consumption without providing any meaningful benefit.
That’s why system design should start with the requirements of the equipment using the air, not simply the size of the compressor someone thinks the facility needs.
Why Proper Compressor Sizing Matters
Bigger isn’t always better.
An undersized compressor may struggle to keep up with demand, causing pressure to fall during periods of high consumption. That can lead to production interruptions or inconsistent equipment performance.
An oversized compressor can create a different problem: unnecessary energy consumption and inefficient operation.
The first step in sizing a system is understanding the facility’s demand profile. Average demand matters, but so do peak demand, minimum demand and the timing of those demands.
For example, a facility may have high compressed air consumption during production but significantly lower demand during breaks, shift changes or overnight hours.
Understanding those patterns can help determine whether a fixed-speed, variable-speed or multi-compressor system makes the most sense.
It can also prevent the classic compressed-air mistake of buying more compressor than the facility needs and then wondering why the electric bill is so high.
Courtesy: Adobe Stock
Fixed-Speed Versus Variable-Speed Compressors
Fixed-speed and variable-speed compressors approach changing demand differently.
A fixed-speed compressor generally operates at a relatively constant motor speed and uses its control system to respond to changes in demand.
A variable-speed compressor can adjust motor speed as demand changes, allowing the compressor’s output to more closely follow the system requirement.
This can be particularly useful in facilities where demand changes throughout the day. Instead of producing the same amount of compressed air regardless of whether the plant is running at full production or operating at a fraction of capacity, a variable-speed system can adjust its output.
The potential energy savings depend on the individual system and its load profile. Variable-speed technology is not automatically the right answer for every application, which is why analyzing actual demand is important.
The Role of Air Storage
Air receivers, commonly called storage tanks, provide another important function in a compressed air system.
An air receiver stores compressed air and acts as a buffer between supply and demand. When demand temporarily increases, stored air can help support the system without requiring the compressor to immediately respond to every fluctuation.
Storage can also help stabilize system pressure and reduce unnecessary compressor cycling.
There are two common storage locations. Wet storage is installed upstream of the dryer and can assist with cooling and moisture separation. Dry storage is installed downstream of the air treatment equipment and provides a reservoir of treated compressed air.
The appropriate amount of storage depends on the system design, demand profile and application. More storage isn’t automatically better, either. The goal is to use storage strategically to support the overall system.
Why Compressed Air Treatment Is Important
Compressed air doesn’t come out of the compressor ready for every application.
Atmospheric air contains water vapor, and compression concentrates that moisture. Depending on the compressor type and operating environment, the air may also contain oil or other contaminants.
If moisture and contaminants make their way downstream, they can cause corrosion, damage pneumatic equipment and affect processes or end products.
That’s where air treatment comes in.
Air Dryers
As compressed air cools, water vapor can condense into liquid water. Excess moisture can cause corrosion in piping and create problems for downstream equipment.
Air dryers reduce moisture to the level required by the application.
Common dryer technologies include refrigerated dryers, desiccant dryers and membrane dryers. The right choice depends on the required pressure dew point and operating conditions.
Filtration
Filters remove contaminants from compressed air. Depending on the application, filtration may target particles, oil aerosols, moisture and other contaminants.
The filtration system should be matched to the required air quality. Too little filtration can allow contaminants to reach sensitive equipment, while unnecessary filtration can increase pressure drop and energy consumption.
The goal isn’t to make the air “as clean as possible.” It is to make it as clean as the application requires.
Compressed Air Quality
Not every compressed air application needs the same level of air purity.
A pneumatic tool in a machine shop and a process in a pharmaceutical facility may both use compressed air, but their requirements can be dramatically different.
Compressed air quality is commonly evaluated based on contaminants such as solid particles, water and oil. ISO 8573-1 provides a framework for classifying compressed air quality.
The appropriate air treatment system should therefore be determined by the requirements of the process and equipment using the air.
This is especially important in applications where compressed air comes into direct or indirect contact with a product.
The Distribution System
Once compressed air has been generated and treated, it still must get where it is going.
The distribution system includes piping, valves, regulators and connection points. Its job sounds straightforward, but poor distribution design can undermine an otherwise well-designed compressed air system.
Undersized piping, excessive bends, long runs and poorly designed connections can create pressure drop. Leaks can make the problem even worse.
Larger facilities often use looped or ring-main distribution systems, which can allow compressed air to reach points of use from multiple directions.
The goal is to deliver the required volume of air at the required pressure without creating unnecessary restrictions along the way.
Compressed Air Leaks
Compressed air leaks are among the most common sources of energy waste in industrial systems.
The frustrating part is that leaks aren’t always obvious. A small leak at a fitting or connection might not be noticeable, but hundreds of small leaks throughout a facility can add up quickly.
Leaks tend occur around pipe connections, hoses, valves, fittings, regulators and quick couplers.
The compressor has no idea air is escaping. It simply keeps working to replace it.
Regular leak detection and repair can be one of the simplest ways to improve compressed air efficiency.
Monitoring and Control
Modern compressed air systems can provide significantly more information than simply telling an operator whether the compressor is running.
Monitoring systems can track pressure, flow, temperature, energy consumption, operating hours and equipment status.
That information can help facility operators understand how their system is performing and identify changes that may indicate a potential problem.
Control systems can also coordinate multiple compressors to better match supply with demand. Rather than having individual compressors operate independently, a coordinated system can determine which machines should run and when.
The result can be better system stability and more efficient operation.
How to Improve Compressed Air Efficiency
Improving compressed air efficiency doesn’t necessarily require replacing the entire system.
Sometimes the biggest opportunities are surprisingly simple.
Start with leaks. A leak detection program can identify wasted air that the compressor is producing but the process never uses.
Next, look at system pressure. If equipment can operate reliably at a lower pressure, reducing system pressure can potentially reduce energy consumption.
Air treatment should also be maintained properly. Dirty filters, saturated dryers and excessive pressure drop can all affect system performance.
Finally, monitor the system. Understanding when and where compressed air is being consumed provides valuable information for making future decisions.
Common Compressed Air System Mistakes
One of the most common mistakes is selecting equipment based solely on horsepower. While horsepower is important, actual airflow, pressure and demand characteristics are equally important.
Another common mistake is operating at unnecessarily high pressure. More pressure can sound like more performance, but it can also mean more energy consumption.
Ignoring leaks is another frequent problem. A system can be technically capable of producing enough air while still wasting a significant amount of it.
Poor piping design can also create unnecessary pressure drop. And finally, designing a system entirely around today’s production requirements can leave little room for future expansion.
The best compressed air systems consider the facility as it exists today while keeping an eye on where production is headed tomorrow.
Designing a Compressed Air System for the Future
A compressed air system should be looked at as a long-term utility rather than a one-time equipment purchase.
Before designing a new system or upgrading an existing one, consider not only the current demand, but also future production growth, required pressure, air quality, demand variability and environmental conditions.
Energy efficiency and maintenance requirements should also be part of the conversation.
Future expansion is particularly important. A system that is perfectly sized today may become inadequate if production increases significantly. At the same time, installing excessive capacity “just in case” can create unnecessary capital and operating costs.
The objective is balance: enough capacity to meet current requirements, enough flexibility to accommodate reasonable growth and enough visibility to know when the system needs to change.
How to Get the Most from a Compressed Air System
Compressed air may look simple from the outside. Air goes into a compressor, gets compressed and eventually comes out the other end.
But a reliable industrial compressed air system is much more than that.
It is a network of compressors, storage, dryers, filters, piping, controls and monitoring equipment that must work together to deliver the right pressure, flow and air quality when production needs it.
Proper sizing can prevent unnecessary capacity and energy consumption. Effective air treatment protects equipment and processes. Well-designed distribution reduces pressure losses. Leak management prevents wasted energy. Monitoring and maintenance help keep the system performing over time.
Most importantly, compressed air should be treated as a complete system rather than a collection of individual components.
Because when compressed air is doing its job, nobody really thinks about it.
And honestly, that’s usually the goal.
The best compressed air system is the one that quietly does its job in the background, keeps production moving and gives everyone one less thing to worry about.
Jayme Leonard, Atlas Copco Compressors, Rock Hill, South Carolina
Jayme Leonard
Jayme Leonard is a Digital Marketing Specialist at Atlas Copco Compressors.
