Gears and Bearings
Gears are mechanical devices that are used to transmit power and motion from one shaft to another. They are used to change the speed, torque and direction of rotation of a shaft and are commonly used in a wide range of applications. Bearings are mechanical devices that are used to support and guide moving parts, such as shafts and other rotating parts and reduce friction and wear between moving components. They are used in a wide range of applications, from small consumer products to large industrial machinery and play an important role in the smooth operation of many types of equipment.
