Instruments and controls
By Staff March 10, 2004
Pressure gauges
Thermoplastic pressure gauges monitor vacuum and positive system pressures up to 15,000 psi and feature 41/2 and 6-in. dial sizes. Gauges have lower back mount and bottom mount configurations, and are available with male NPT or tube adapter end connections.
Swagelok Co. , swagelok.com , Write 327 on PE card
Status datalogger
Series OM-50 dataloggers record device on/off or open/closed states and store the time and date for each. Units have LED status indicators as well. Datalogger connects to PC using RS-232 interface and is Windows compatible.
Omega Engineering, Inc. , omega.com , Write 328 on PE card
Temperature controller
E5AR and E5ER multiloop temperature/process controllers have a fast sampling time and allow selection among thermocouple, platinum RTD, analog current, or analog voltage inputs. Controllers display process variable (PV), setpoint (SP), and other important data in a backlit LCD display.
Omron Electronics, LLC , omron.com , Write 329 on PE card
Wireless I/O
RAD-DATA-BUS system data radios move RS-232, RS-422, and RS-485 serial data from any PLC or controller with Modbus or DF1 protocols and allows users to read and write analog and digital I/O from remote locations. Each transceiver is a master, slave, and store-and-forward repeater.
Phoenix Contact, Inc. , phoenixcon.com , Write 330 on PE card
Pocket temperature probe
TPP temperature pocket probes allow quick temperature checks of liquids and surfaces. Features include 0.1-F resolution, LCD display, data hold, protective cover with pocket clip for immersion probe, and included battery. Probes come in F and C versions.
Wavetek Meterman Test Tools , metermantesttools.com , Write 331 on PE card
