Building a system integration strategy that pays for itself
When integration is planned from the start, it changes nearly every downstream decision for the better. Discover a more practical framework for approaching system integration across the automation life cycle with two real-world examples and five implementation tips.
System integration project insights
  • Understand the importance of starting with a structured discovery phase.
  • Learn how to design for validation and compliance from the beginning.
  • Discover how to see measurable results.
Manufacturers often treat system integration as the final step in an automation project, something that gets handled after the hardware is selected and the controls architecture is locked in. That instinct is understandable, but it tends to be expensive. When integration is planned from the start, it changes nearly every downstream decision for the better. Costs drop, timelines shorten and the resulting system is far easier to operate, maintain and extend.
A practical framework for approaching system integration across the automation life cycle was established in two real-world examples from Grantek projects in the food and beverage and pharmaceutical manufacturing sectors.
Start system integration with a structured discovery phase
The single highest-leverage activity in any integration project is the upfront discovery and road-mapping session. Before any technology is specified or purchased, the integrator and the manufacturer need to sit together and uncover the real constraints.
That conversation must go beyond functional requirements. Budget impact is a constraint. Regulatory compliance is a constraint. Reliability requirements, scalability needs and the availability of internal technical staff to maintain the system over time are all constraints. So is the risk profile of adopting newer versus more established technologies.
In working with a food and beverage manufacturer, for example, the engagement opened with exactly this kind of session. The manufacturer was dealing with customer complaints about product placement non-conformances visible through transparent packaging trays. Labor costs had risen because workers were manually inspecting outgoing product. The instinct might have been to jump straight to a machine-vision solution, and a deep learning-based camera system was in fact the first option evaluated.
What the road-mapping session revealed was that the manufacturer’s SKU count was large and growing, that product features changed frequently and that some runs were short. All those factors added up to a system that would require constant retraining and heavy ongoing overhead. The risk was too high for the return. That conclusion could only be reached by taking the time to map the full operating context before specifying technology.
The change that followed, to a vision inspection solution better suited to the actual production environment, produced a successful outcome precisely because the constraints had been identified before any hardware was committed.
Tips: Build an integration roadmap around four categories of constraints: functional and technical requirements, regulatory obligations, financial boundaries (both capital and operating) and organizational capacity to maintain what gets built. Rank them explicitly, because tradeoffs are inevitable and it is better to make them intentionally.
Match technology selection to the full life cycle, not just the install
A common source of poor return on investment in integration projects is selecting technology that performs well at commissioning but creates ongoing costs that erode the initial value. Licensing structures, vendor lock-in, support requirements and scalability limitations all carry long-term financial weight that is easy to underestimate when evaluating options at the front end.
During a plant expansion project with a pharmaceutical manufacturer, the application needed a new historian system; the commercial options on the market carried licensing costs well into the six figures, upfront and recurring. Several of those options also imposed per-tag pricing, which is a significant budget risk for a facility that might grow from 5,000 to 100,000 data points over time.
The team worked through a detailed constraint analysis: regulatory compliance requirements under FDA 21 CFR Part 11 and Health Canada regulations, data retention timelines of up to 15 years, performance at scale and interoperability with existing supervisory control and data acquisition (SCADA) and manufacturing execution system (MES) technologies across roughly 20 equipment units and 500 I/O devices.
The solution used combined a SCADA and visualization layer with an open-source backend: PostgreSQL and TimescaleDB for time-series data management, pgpool as database middleware and Ubuntu Linux as the operating system, running in a virtualized environment. The commercial licensing costs disappeared entirely on the backend. Per-tag pricing was no longer a variable. The system was deployed within six months, compared to the 12 or more months typical for traditional historian implementations.
The financial outcome was more than $100,000 in annual savings, with full scalability to over 100,000 tags and no vendor lock-in.
Tips: When evaluating integration solutions, build a five-year total cost of ownership model that includes licensing (and how licensing scales with growth), support obligations, upgrade paths and the internal labor required to maintain the system. Technology that looks expensive upfront sometimes has the lower long-term cost. The reverse is also true.
Design for validation and compliance from the beginning
In regulated industries, integration projects carry a documentation burden that can be as demanding as the technical work itself. Computer system validation (CSV) for pharmaceutical manufacturers, for example, requires that systems meet defined standards and that every aspect of that compliance can be demonstrated with traceable evidence.
Too often, documentation is treated as a deliverable that gets produced after the technical work is done. That approach creates significant risk. Specifications written after implementation may not fully reflect how the system works, and compliance gaps discovered late in a project are expensive to close.
The better practice is to treat documentation as a parallel workstream that begins at the same time as design. Functional specifications, design specifications and user requirements specifications should be developed together, with each layer referencing the others. Factory acceptance testing (FAT) and site acceptance testing (SAT) protocols should be drafted before testing begins, not after.
In the pharmaceutical historian project described above, delivery of a complete documentation package aligned to the user requirement specification, covering visualization and performance specifications, sampling rates, dead bands, data interpolation protocols and implementation of a unified namespace to standardize tag paths across the system. The FAT and SAT documentation was built from reusable templates and designed explicitly to reference each other, so that acceptance tests executed before moving onsite was cited in the client’s installation operational qualification package.
The result was a substantial reduction in the client’s validation timeline. By the time the system reached the client’s production environment, the compliance record was already largely built.
Tips: For any regulated application, identify all applicable standards at the start of the project and map each system requirement back to a compliance obligation. Build FAT and SAT templates early and ensure that test execution during commissioning produces records usable in the final validation package. Reusable templates from previous projects can compress this timeline considerably.
Use pilots to reduce risk before full deployment
One of the most effective risk-management tools available to manufacturers undertaking integration projects is the structured pilot program. Rather than committing to a full-line deployment based on vendor claims and lab testing, a pilot puts the solution into the actual production environment, with real products and real process variables, before the capital commitment is made.
The Ontario food and beverage project followed this model deliberately. After the initial deep learning option was ruled out, a machine vision inspection system was installed on one segment of the production line first. The pilot included specifying a specialized photo eye to handle the trigger detection challenges created by the transparent packaging, a detail that would not have surfaced outside a real production environment.
Only after the pilot demonstrated reliable performance was the solution expanded to the second production line segment. Reporting functions were then added, giving operators and plant floor managers reject counts by shift with images of non-conforming packages stored for quality review. Senior leadership gained access to data that could inform decisions about other lines and facilities.
The structured approach, feasibility study, then pilot, then full deployment, added time to the front end of the project but eliminated the risk of a costly full-line rollout that might have required rework or replacement.
Tips: For any integration project that introduces a technology new to the facility, design the pilot scope to include the specific production conditions that represent the highest risk. Transparent packaging, unusual product geometries, non-standard communication protocols and legacy equipment interfaces are all examples of factors that need to be validated in the real environment before committing to full deployment.
Build scalability into the architecture
Manufacturing facilities are living systems. Production volumes change. Product lines are added or retired. Regulatory requirements evolve. Any integration solution that cannot accommodate those changes without significant rework or additional licensing cost is going to create problems within a few years of commissioning.
Scalability needs to be an explicit design criterion, not an afterthought. That means asking, before any architecture is finalized, how the system handles tag additions, new users, additional reporting requirements and integration with new upstream or downstream systems.
In the pharmaceutical historian project, scalability was one of the four primary constraints identified at the start. The architecture Grantek selected addressed it at every layer. A unified namespace standardized tag paths so that adding new equipment did not require restructuring the data model. TimescaleDB handled compression and tiered storage in ways that kept performance predictable as data volumes grew. The open-source stack eliminated the per-tag pricing that would have made growth expensive under a commercial historian.
Guidance on how the client’s team could manage future scaling independently, covered tag additions, gateway expansion and storage architecture. That knowledge transfer is a form of value delivery in integration projects, because a system the client team understands and can maintain is far less costly over its life cycle than one that requires the integrator to return for every change.
Tips: Evaluate scalability across three dimensions: data volume (tags, sampling rates, storage), system scope (new equipment, new sites, new users) and integration breadth (connections to MES, enterprise resource planning, cloud data platforms). An architecture that handles all three without incurring additional licensing costs or requiring fundamental redesign will deliver substantially better long-term return on investment (ROI).
A framework for the full life system integration cycle
System integration is not one event. It is a practice that spans design, specification, commissioning, operations and eventually upgrade or decommissioning. The manufacturers who get the most value from their automation investments are the ones who treat integration discipline as a core competency rather than a project phase.
The principles described here, structured discovery, life cycle cost evaluation, compliance-first documentation, pilot-based risk management and scalability-driven architecture, apply across industries and project types. They are not proprietary to any technology stack or vendor relationship. They are ways of thinking about integration that consistently produce better outcomes.
When these principles are applied together, the results speak for themselves: shorter commissioning timelines, lower total cost of ownership, stronger compliance posture and systems that continue to deliver value as the facility evolves. That is what maximizing ROI from automation, controls and instrumentation looks like in practice.
Jim Toman is a functional consultant at Grantek, Weston, Florida. Edited by Sheri Kasprzak, executive editor, Control Engineering, Plant Engineering, [email protected].
Keywords
System integration, project management
Consider this
Do your system integration projects seek to maximize return on investment or are other priorities guiding outcomes?
You also might like
Global System Integrator Database
https://si.arrowfly.com/integrators/grantek-systems-integration-inc
Jim Toman, Grantek
Jim Toman is an MES functional consultant at Grantek, Weston, Florida. https://grantek.com/
