Why lubricant labels are so important
Misreading labels and lubricant viscosity in real-world applications can lead to costly downtime, potential operational problems and even environment compliance issues.
Learning objectives
  • Recognize the operation risks of relying solely on lubricant labels, including the potential for equipment damage, downtime, safety exposure and environmental issues.
  • Interpret key information found in technical data sheets (TDS) and safety data sheets (SDS) to evaluate lubricant performance characteristics, safety considerations and suitability for specific plant applications.
  • Apply a structured lubricant selection process that verifies OEM requirements, performance specifications and safety documentation to reduce misapplication risks and improve equipment reliability.
Lubricant insights
  • While a lubricant label provides a quick reference for viscosity and application, relying on it alone can lead to system failures if detailed performance specifications are overlooked.
  • To ensure equipment reliability and worker safety, maintenance professionals must look beyond the packaging to the technical and safety data sheets that define the true operational profile of a lubricant.
In industrial plants, lubrication decisions can often appear straightforward. A technician checks the lubricant equipment manual, confirms the viscosity grade on the drum and fills the system. The process seems routine, until it isn’t.
Consider a common scenario. A technician pulls a drum labeled “ISO 46 Hydraulic Oil.” The viscosity matched what’s listed in the equipment manual, so the lubricant goes into service. Weeks later, the hydraulic system begins running hotter than expected. Valves start sticking. Maintenance crews notice sluggish actuator performance. Eventually, a teardown reveals varnish deposits and signs of oxidation throughout the system. The label wasn’t wrong. It just wasn’t the full story.
Lubricant misapplication rarely occurs because someone ignores instructions. Often, it happens because decisions are made using partial information. Viscosity may be confirmed, but performance specifications are overlooked. Marketing claims are trusted, but performance data isn’t reviewed. Safety warnings may be skimmed, but handling requirements are not reinforced.
In modern plants, lubrication decisions influence far more than component wear. They affect equipment reliability, warranty compliance, energy efficiency, worker safety and environmental responsibility. For engineers and maintenance leaders, understanding lubricant documentation is essential.
The label is only the starting point. The real insight lies in the technical and safety documentation behind it.
What a lubricant label tells you
Lubricant packaging labels are designed for quick identification. They provide essential information, but they are not intended to communicate every performance characteristic of a product.
Typically, a lubricant label includes several key elements:
  • Viscosity grade, such as SAE or ISO classification
  • Service category, such as industry standards or engine classifications (API, ACEA)
  • Application type, identifying the intended system (hydraulic, gear, engine oil, etc.)
  • Marketing descriptors, including terms like synthetic, premium or high-performance
These identifiers are helpful, but they do not reveal the complete performance profile of a lubricant.
Critical details that typically do not appear on the label include:
  • Additive chemistry and concentration levels
  • Shear stability characteristics
  • Oxidation resistance and service life
  • Zinc or phosphorous content in anti-wear formulations
  • Foaming characteristics
  • Water separation ability (demulsibility)
  • Seal compatibility
  • Worker exposure and safety concerns
In other words, two lubricants can carry the same viscosity grade while performing very differently in operation.
For engineers responsible for equipment reliability, relying solely on label information can create unnecessary risk. To make informed decisions, maintenance professionals must look beyond packaging and review the documentation that defines a lubricant’s true operational performance.
How to read a lubricant product data sheet
The technical data sheet (TDS), sometimes called a product data sheet, translates marketing claims into measurable performance data. It is one of the most valuable documents for evaluating lubricant stability in plant environments.
Understanding how to interpret a TDS allows engineers and technicians to determine whether a product will perform reliably under specific environments.
The first step in reviewing a TDS is confirming that the lubricant is designed for the correct application. Questions to consider include:
  • Is the lubricant intended for engines, hydraulic systems, compressors or gearboxes?
  • Does it support the load conditions of the equipment?
  • Is it formulated for the expected temperature range?
Different industrial systems impose different demands on lubricants. A product optimized for one environment may perform poorly in another.
Figure 1: Key properties in a lubricant technical data sheet. Courtesy: CITGO Petroleum Corp.
Key performance properties to review
A TDS contains numerous performance metrics. Some of the most important include the following.
Kinematic viscosity (40°C & 100°C): Viscosity defines a fluid’s resistance to flow. Most TDS provide viscosity measurements at 40°C and 100°C. Why two temperatures? Because viscosity changes significantly as temperature changes. Measuring viscosity at both moderate and elevated temperatures helps engineers understand how the lubricant will behave during cold start conditions and under operating heat.
Viscosity index (VI): The VI indicates how stable a lubricant’s viscosity remains as temperatures fluctuate. A higher VI means the oil maintains more consistent thickness across a wider temperature range. This stability is particularly valuable in systems exposed to varying ambient conditions or fluctuating operating temperatures.
Pour point: The pour point represents the lowest temperature at which an oil can still flow.
In colder environments or during startup conditions, an oil with a high pour point may struggle to circulate effectively. Poor flow during startup can result in inadequate lubrication during the most critical moments of equipment operation.
Flash point: The flash point identifies the temperature at which oil vapors may ignite in the presence of a spark and serves primarily as an indicator of flammability and handling safety rather than a maximum operating temperature.
Zinc and phosphorous levels: Many anti-wear additives rely on zinc and phosphorous compounds, commonly referred to as ZDDP. These additives provide protection under high-load conditions, especially in hydraulic pumps and heavily loaded components. But their  presence and concentration must align with original equipment manufacturer (OEM).specifications due to potential material-compatibility and system-sensitivity considerations.
Oxidation stability: Oxidation resistance determines how well an oil maintains its integrity over tie when exposed to heat and oxygen. Poor oxidation stability can lead to varnish formation, sludge buildup and shorten oil life, all of which can contribute to maintenance costs and system breakdowns.
Demulsibility: Industrial systems often encounter moisture contamination through condensation or environmental exposure. Demulsibility refers to an oil’s ability to separate from water. In systems such as turbines, compressors and hydraulic reservoirs, good water separation helps prevent corrosion and maintains lubrication performance.
Foam test results: Foaming occurs when air becomes entrained in the lubricant. Excessive foam can reduce lubrication effectiveness, increase oxidation and cause erratic system behavior. TDS foam test data provides insight into how well the lubricant resists aeration.
The TDS converts performance claims into quantifiable data. It provides the numbers needed to evaluate whether a lubricant is suitable for a specific application.
Figure 2: Understand the lubricant selection process. Courtesy: CITGO Petroleum Corp.
How to read an SDS
While the TDS focuses on performance, the safety data sheet (SDS) focuses on risk management. Plant maintenance leaders must consider several factors when evaluating lubricants:
  • Worker exposure risks
  • Storage requirements
  • Fire hazards
  • Disposal practices
  • Environmental compliance
The SDS provides the regulatory information needed to manage these considerations.
The SDS is a regulatory document designed to communicate chemical hazards. In the United States, it must comply with standards established by the Globally Harmonized System of Classification and Labelling Chemicals (GHS) and adopted by the Occupational Safety and Health Administration. SDS documents follow a standardized 16-section format, ensuring consistent information across manufacturers.
Several sections of the SDS are particularly relevant for plant engineers and maintenance teams when reviewing the document.
Section 2: Hazard identification: This section provides a quick overview of safety concerns, including:
  • Signal words such as “danger”or “warning”
  • Hazard pictograms
  • Statements describing potential risks
Section 4: First aid measures: This section outlines response procedures if exposure occurs, including contact with skin, eyes or inhalation.
Section 7: Handling and storage: This guides proper storage conditions, including temperature control, ventilation requirements and incompatible materials.
Section 8: Exposure controls/personal protective equipment (PPE): This details recommended PPE and exposure limits for workers handling the product.
Section 9: Physical and chemical properties: Provides additional data such as vapor pressure, density and flash point.
Section 10: Stability and reactivity: Identifies conditions that could cause chemical instability or hazardous reactions.
Section 12: Ecological information: Describes environmental impact considerations if product enters soil or water systems.
In practical terms, the SDS protects people, while the TDS protects equipment. Both documents must be understood to ensure safe and reliable operations.
Approvals versus marketing language
Once common source of confusion in lubricant selection involves wording on labels and marketing materials. Phrases like “approved by” or “meets requirements of” may appear similar but represent very different levels of verification.
  • “Approved by” typically means the product has undergone formal testing and certification by an OEM.
  • “Meets requirements of” often indicates the manufacturer believes the product aligns with the specification, but it has not necessarily been formally approved.
OEM approvals matter because many equipment warranties require the use of approved lubricants. Using a product that merely “meets requirements” could create complications if warranty claims arise.
Maintaining documentation of lubricant approvals protects both equipment performance and plant management accountability.
Red flags in labels or data sheets
Certain warning signs should prompt closer scrutiny when evaluating a lubricant. Potential red flags to watch for include:
  • No publicly available technical or safety documentation
  • Missing viscosity values at both 40°C and 100°C
  • Lack of referenced test methods such as ASTM standards
  • No document revision date
  • Vague marketing claims without supporting data
  • No manufacturer contact information
Lack of transparency in documentation is an indicator of product unreliability.
Training teams on lubricants
Even the best documentation cannot prevent errors if maintenance teams lack the training to interpret it. Plant managers can reduce lubrication mistakes through several practical measures:
  • Establish a standardized approved lubricant list for all equipment
  • Maintain digital access to TDS and SDS documents
  • Conduct annual lubrication literacy training for technicians
  • Perform routine audits of lubrication storage areas
Investing in lubrication education can significantly improve equipment reliability and reduce safety risks and maintenance costs.
Lubricant success
Lubrication decisions are not routine maintenance tasks. While labels provide quick identification, they represent only a fraction of the information needed to determine whether a lubricant is truly suitable for an application.
The TDS reveals the measurable performance characteristics that determine how a lubricant will behave under load, temperature changes and contamination exposure. The SDS, meanwhile, outlines the procedures necessary to protect workers, manage hazards and maintain regulatory compliance. Both documents are important tools for maintenance and reliability professionals.
For plant engineers and maintenance leaders, relying solely on label information can lead to equipment damage, unplanned downtime, safety risks and environmental exposure. Reviewing the full technical and safety documentation behind a lubricant helps ensure that products are applied correctly and that systems operate reliably. In industrial settings, labels are shorthand, but data sheets are the truth and safety documentation is nonnegotiable.
In modern industrial environments, reliability, safety and compliance depend on making lubrication choices on complete confirmation.
Brandon Thompson, CITGO Petroleum Corp., Houston
Brandon Thompson
Brandon Thompson is Product Marketing Manager, Lubricants at CITGO Petroleum Corp.
