The five-step lubricant decision framework
Plant leaders can follow a structured lubricant evaluation process.
To reduce the risk of misapplication, plant leaders can follow a structured lubricant evaluation process. A practical lubricant review framework includes five important steps:
  1. Confirm original equipment manufacturer (OEM) requirements: Verify the lubricant specifications listed in the equipment manual.
  2. Verify viscosity grade: Ensure the lubricant matches the required viscosity classification.
  3. Confirm industry/OEM specifications: Check for formal approvals or compliance with required standards.
  4. Review technical data sheet (TDS) performance properties: Evaluate critical characteristics such as oxidation stability, viscosity index, demulsibility and foam control.
  5. Check safety data sheet considerations: Confirm appropriate handling procedures, personal protective equipment requirements and storage conditions.
Following this structured process reduces the likelihood of costly lubrication errors.
Brandon Thompson, CITGO Petroleum Corp., Houston
Brandon Thompson
Brandon Thompson is Product Marketing Manager, Lubricants at CITGO Petroleum Corp.
