Articles about motor testing, preventative maintenance, index testing, augmented reality, and operational improvement were Plant Engineering's five most clicked articles from last week, August 7-13. Were you out? You can catch up here.
Plant Engineering’s top 5 most read articles from August 7-13, covered motor testing, preventative maintenance, index testing, augmented reality, and operational improvement. Link to each article below.
1. The benefits of testing a 3-phase electric motor
Testing a three-phase motor with a polarization index test (PI), megger test, or surge test on a regular basis helps extend the life of the motor.
2. Three methods of preventive maintenance that should not be overlooked
Sound level analysis, ultrasonics, and vibration analysis along with other preventive maintenance techniques help prevent unexpected equipment failure and downtime..
3. Polarization index testing benefits
Polarization index (PI) testing is an extension of the insulation resistance test and is designed to check specific issues in a motor such as moisture and insulation deterioration.
4. Augmented Reality for manufacturing and process control applications
Using data analysis to find out what the dominant products within a facility are and the processes used to create them and how they flow within a plant facility is a useful way to make a company Leaner.
5. Rewarding operational improvement: Target changes, not just numbers
Rewarding individual operators, and operations as a group, means recognizing them for their performance and acknowledging their contributions to their organization’s goals.
This list was developed using CFE Media’s web analytics for stories viewed on www.plantengineering.com, August 7-13, for articles published within the last two months.
Sierra Grayson, Production Coordinator, CFE Media, [email protected].
