Sump level regulator
The sump level regulator is specifically designed to maintain tank fluid levels.
The sump level regulator is specifically designed to maintain tank fluid levels. The unit activates the water supply or fluid pump to maintain the correct fluid operating level in each machine tool sump or central tank. It features heavy-duty mechanical components with only two moving parts and can be installed using a simple, two-step process. The regulator is suitable for use with most fluid types.
Zebra Skimmers Corp.
www.zebraskimmers.com
Plant Engineering Staff
