Ring bearings for wide range of medium- to heavy-duty applications
The Kaydon HS Series of ring bearings are efficiently designed for four-point contact, with a rectangular cross-section, deep groove gothic arch raceways and maximum ball complement
The space-saving HS Series slewing ring bearings handle moment loads of up to 139,900 ft-lbs. The ability to deliver load and thrust with significant space savings makes Kaydon the bearings ideal for a wide range of medium-duty to heavy-duty applications, such as cranes, aerial lifts, digger derricks, chute swivels, lift truck rotators, and industrial turntables.
They are efficiently designed for four-point contact, with a rectangular cross-section, deep groove gothic arch raceways and maximum ball complement.
Kaydon
www.kaydonbearings.com
