Network-based control system update for oil, chemical applications
Yokogawa's updated Stardom network-based control system supports Microsoft Windows 10 and has been enhanced for oil and gas well and pipeline operations.
Yokogawa’s updated Stardom network-based control system supports Microsoft Windows 10. It also features a high-speed CPU module comes with a new function that enables Java applications to run on a Stardom controller. In addition, an oil flow rate calculation function has been added to meet the needs of oil and gas well operations. Stardom has been enhanced for oil and gas well and pipeline operations and it also includes functionality for the on-site management of data that reduces the amount of communications traffic between central monitoring rooms and facilities distributed over a wide area. It also features a Duolet function that enables Java applications to run on the FCN controller is now embedded in the high-speed CPU module. It can also be used for small- to medium-size oil, chemical, iron and steel, pulp and paper, food, and pharmaceutical process facilities.
Yokogawa
www.yokogawa.com
– Edited by CFE Media. See more Control Engineering industrial PC products.
