Linear sensor
The Q25L sensor is a magnetically actuated linear displacement sensor designed to detect piston position on pneumatic cylinders. Available with measuring ranges of 100, 125, 160 and 200 mm, the Q25L is well-suited for applications that require precise signal transmission over long measuring distances such as pneumatic pumps, slides, blanking or molding systems.
The Q25L sensor is a magnetically actuated linear displacement sensor designed to detect piston position on pneumatic cylinders. Available with measuring ranges of 100, 125, 160 and 200 mm, the Q25L is well-suited for applications that require precise signal transmission over long measuring distances such as pneumatic pumps, slides, blanking or molding systems. By using an external magnet as a position indicator, the sensor may be used in additional applications such as moving platforms, point line measurement or other specially designed equipment where a cylinder is not present.
TURCK , www.turck.us
Plant Engineering
Plant Engineering Staff
