The EXCEN-CRUSHER is designed for high volume operations in large industrial power plant installations. The improved 54 by 43-inch crusher is designed to reduce clinker size in wet or dry applications with pneumatic, hydraulic or mechanical conveying system applications. It features four-bolt chrome-alloy white cast iron cams; a universal pre-drilled gearmotor mount; and two types of seals.
The EXCEN-CRUSHER is designed for high volume operations in large industrial power plant installations. The improved 54 by 43-inch crusher is designed to reduce clinker size in wet or dry applications with pneumatic, hydraulic or mechanical conveying system applications. It features four-bolt chrome-alloy white cast iron cams; a universal pre-drilled gearmotor mount; and two types of seals. The standard fixed seal uses spring loaded packing glands and seal rings. The floating seal includes a flexible diaphragm.
United Conveyor Corp. www.unitedconveyor.com
