Heating compound
Diff-Tranz heat-transfer compound increases the efficiency of platen heaters by maximizing their contact with the vacuum diffusion pumps on which they are installed.
Diff-Tranz heat-transfer compound increases the efficiency of platen heaters by maximizing their contact with the vacuum diffusion pumps on which they are installed. The compound fills gaps between the irregular surface of the pump’s boilerplate and the smooth surface of the heater, ensuring uniform transfer of heat to the boilerplate. Applied with a putty knife, the compound withstands temperatures of up to 1,250 F.
Dalton Electric Heating Co. Inc.
www.daltonelectric.com
Plant Engineering
Plant Engineering Staff
