Grease handles extreme pressures
Paragon 3000 grease passes a full 100-lb Timken Load Test, is extremely stable, and changes little in the 100,000 double stroke test, from a penetration of 280-274 in its consistency.
Paragon 3000 grease passes a full 100-lb Timken Load Test, is extremely stable, and changes little in the 100,000 double stroke test, from a penetration of 280-274 in its consistency. The compound displaces water on metal surfaces and retains extreme pressure protection in the presence of 20% water. This grease does not melt below 630 F, but may require more frequent application above 450 F.
Texas Refinery Corp.
www.texasrefinery.com
Circle 387
