Backflow protection valve
The Waterflex check valve provides low head-loss in high- pressure potable water applications.
The Waterflex check valve provides low head-loss in high- pressure potable water applications. The valve uses line pressure and backpressure to function and does not require any external energy. Forward hydraulic pressure folds the elastometer disk away from the perforated plate to allow flow. The valve can be purchased in sizes of up to 96 inches in diameter. Tideflex Technologies www.tideflex.com
Plant Engineering
Plant Engineering Staff
