Viscosity sensor
The CE- and ATEX-compliant MXBOC viscosity sensor measures viscosities from 0.1 to 100,000 CPS, requiring 40-psi dry air and a three-way, 24-Vdc air valve. PLC-compatible, it’s designed for both water and solvent-based applications with tanks between 7 and 26 inches deep.
The CE- and ATEX-compliant MXBOC viscosity sensor measures viscosities from 0.1 to 100,000 CPS, requiring 40-psi dry air and a three-way, 24-Vdc air valve. PLC-compatible, it’s designed for both water and solvent-based applications with tanks between 7 and 26 inches deep. The sensor features a one-bolt mounting mechanism, and its all-stainless-steel-wetted parts are removable for cleaning and sterilization.
Norcross Corp.
www.viscosity.com
Plant Engineering
Plant Engineering Staff
