Solenoid-driven diaphragm liquid metering pump
Mountable in almost any position, the FMM20 solenoid-driven diaphragm pump for metering liquids comes factory-calibrated to dispense volumes at 20 μl-per-stroke.
Mountable in almost any position, the FMM20 solenoid-driven diaphragm pump for metering liquids comes factory-calibrated to dispense volumes at 20μl-per-stroke, but it can be customized for calibration to any specified dosing between 5 and 25 μl-per-stroke and can be adjusted in the field to any stroke within the range. The pump integrates a noise-suppression system for quiet operation and is flow-tight in both directions, sealed internallyfor pressures at rest up to 0.5 bar.  Low current and power consumption generate energy efficiencies.
KNF Neuberger Inc.
www.knf.com
Plant Engineering Staff
