Lightweight pressure calibrators
The 719 electric pressure calibrator has a built-in electric pump that makes it possible to quickly calibrate and test pressure devices with one hand, and a cleanout port.
The 719 electric pressure calibrator has a built-in electric pump that makes it possible to quickly calibrate and test pressure devices with one hand, and a cleanout port. The electric pump can be programmed to set target pressures or limit pressure to eliminate over pressurization. It is designed to perform 5,000 pump cycles between rebuilds. Its unique cleanout port makes it easier to service the pressure calibrator without sending it out for repair. The cleanout port minimizes pump failures caused by accidental exposure to contaminating fluids.
Fluke Corp.
www.fluke.com
Plant Engineering Staff
