Lever action barrel pump
Model 1340 lever action barrel pump is designed for industrial and other applications.
Model 1340 lever action barrel pump is designed for industrial and other applications. The unit’s extended pump body improves top-of-barrel clearance while providing a 14.0 fluid ounce minimum flow per stroke. The pump features a removable, non-drip spout that, when removed, reveals a threaded hose connection. The telescoping pick-up tube fits 16- to 55-gallon drums. Its three-tier threaded bung fits standard 2-inch and 1.5-inch drums, and plastic drums using 56 x 4 millimeter buttress threads.
Lincoln Industrial Corp.
www.lincolnindustrial.com
Plant Engineering
Plant Engineering Staff
