Heavy-duty drum motor
Available in two versions, the 220 Series drum motor features an internal gearing system with 97% efficiency and uses less power than many conventional drives.
Available in two versions, the 220 Series drum motor features an internal gearing system with 97% efficiency and uses less power than many conventional drives. It is self contained, enclosing the motor, gearbox and bearings inside a steel shell, and it is IP66/67-food-grade-approved. The motor can match irregular load conditions for normal heavy-unit handling. It is available with numerous options, including a crowned, mild-steel shell to ensure belt tracking, , a mechanical backstop, sprocket mounting and matching idler pulleys.
Interroll
www.interroll.us
Plant Engineering
Plant Engineering Staff
