Expansion joint is flat and waterproof
RedLine expansion joint can be used on horizontal and vertical surfaces, and in any built-up or modified bitumen application. The product can also be encapsulated in epoxy resin when applied on a concrete or metal surface.
RedLine expansion joint can be used on horizontal and vertical surfaces, and in any built-up or modified bitumen application. The product can also be encapsulated in epoxy resin when applied on a concrete or metal surface. The flat profile waterproof expansion and control joint can be formed in any shape. Situra, Inc.
