Chain lube system uses electrostatic nozzles
AutoJet Electrostatic Lubrication System uses electrostatic nozzles to apply lubrication to ball bearings and other key areas of the chain
The AutoJet Electrostatic Lubrication System is ideal for use in many operations including packaging, beverage processing, chain manufacturing and can-making. The system uses electrostatic nozzles to apply lubrication to ball bearings and other key areas of the chain. Extremely high transfer efficiency ensures uniform coverage with minimal waste. Chain life is extended and the downtime for chain repair and maintenance due to overspray and misting is dramatically reduced. Users of the system report increases in production time up to 20%.
Spraying Systems Co.
