2011 POY Finalists: Compressed Air
Finalists in Compressed Air in Plant Engineering’s 2011 Product of the Year competition
Air nozzle
The Model 1108 SS Atto Super Air Nozzle has been engineered for precise blowoff with efficient, high-volume, high-velocity airflow. The nozzle measures only 0.5-in. with a diameter of only 0.16-in., permitting installation in tight spaces. High amplification of airflow and a strong blowing force of 2.0 oz are achieved with minimal air consumption of 2.5 SCFM at 80 PSIG. The airflow cannot be blocked, which meets the OSHA standard for dead-end pressure, 29 CFR 1910.242(b). Sound level is low at 58 dBA, which meets OSHA noise requirement 29 CFR 1910.95(a) and is CE compliant.
EXAIR Corp.
Compressed air filter
The Finite T-Series top-loading compressed air filters are designed to remove solid and liquid contaminants up to 99.995%, which allows for easy element replacement. The filter housings have been designed to make element replacement faster, reducing downtime and increasing production volumes. The loading filters are designed to protect internal components of a refrigerated dryer by removing compressor oil carryover, which can compromise a dryer’s operation. The Finite T-series meets OEM requirements and is ideal for usage in limited spaces and for mounting inside cabinets.
Parker Hannifin Corp.
Nitrogen generators
The TNX Series of on-site nitrogen generators offers a revolutionary solution to the problem of increasing nitrogen production without having to make large upfront capital equipment expenditures. The expandable TNS Series gives companies the flexibility to buy the capacity they need today and easily increase that capacity as their nitrogen needs grow. The TNX Series has been designed with features that provide a combination of innovation and practicality, including a small footprint that maximizes efficiency while minimizing space needs and a high visibility control panel that allows for easy and clear system monitoring.
The Titus Co.
Flame-free press system
Vic-Press, a flame-free press system, is an industrial-grade solution for joining small-diameter piping systems. Vic-Press has pressure tolerance of up to 500 PSI and is ANSI/NSF 61 certified for potable water up to 180 F. The Vic-Press system is available for 0.5-in to 2-in Type 304/304L and Type 316/316L pipe. Vic-Press products feature Grade “H” HNBR gaskets, suitable for services up to 210 F. Alternative materials, including EPDM, fluoroelastomer, and silicone, are available for services up to 250 F. Vic-Press is designed for a number of wet and dry industrial and commercial applications and general chemical services.
Victaulic
