Simple Solutions
Reading a meter Problem: Trying to take voltmeter readings when the test points are far apart and there is no place to set the meter down can be a problem. Is there an easy way to take the readings? Solution: Get a cable hold down clip that fits one of the probes. These usually have a self-adhesive on the back.
08/01/2001
Reading a meter
Solution: Get a cable hold down clip that fits one of the probes. These usually have a self-adhesive on the back. Attach the clip to the side of the meter and slip the probe into it. Now readings can be taken and seen easily using two hands.
Contributor: Ron Hardison, AFG Industries, Victorville, CA.
Repairing chain
Problem: Mending roller chain while it is still on a drive is a challenging exercise that seems to require three hands. How can you pull the chain together and make a repair?
Solution: Grind a half radius on each jaw of a pair of slip-joint pliers to fit the chain roller. Adjust and squeeze the jaws to pull the chain together while the other hand is free to insert the repair link. The pliers can still be used to bend the cotter pin on the repair link.
Contributor: J.C. Bedenbender, Maintenance Supervisor, United Brick & Tile, Adel, IA
Don't drain the tank
Problem: A hose, filter, or similar item must be disconnected from a hydraulic reservoir or other part of the system somewhere below the fluid level. Draining the tank or system is time consuming and messy. Is there a way to avoid doing this?
Solution: Attach a wet-type vacuum cleaner to the fill pipe of the reservoir. Seal the connection with duct tape and turn the vacuum on. The resulting vacuum in the reservoir prevents any fluid from running out when the system is opened.
Caution: Do not use an electric vacuum cleaner around highly volatile or flammable liquids. An air-operated vacuum cleaner is safer.
Contributor: Galen Duckstein, E.C.O. Coordinator, Wermeer Mfg., Pella, IA
Safety First
In all cases, even if not specifically mentioned in the writeups, verify that the tip does not violate any relevant code, standard, or practice. Always use the appropriate safety equipment and procedures when applying the maintenance tips.
