Networks and Communications Award Winners
02/01/2009
EnclosuresVortex A/C Model #7770
Vortec - ITW Air Management
With essentially no maintenance, the Vortex A/C 7770 provides total enclosure protection from heat and contaminants, with thermostatically controlled, two-stage refrigeration to conserve energy. The new 5,000 BTUH Vortex A/C model 7770 features dual vortex tube cooling units, each with its own reliable mechanical thermostat to provide two-stage levels of refrigeration. The compact, UL listed, Vortex A/C provides reliable, below-ambient cooling in environments up to 175 °F (79 °C), keeping panels safely within a range of 80-90 °F (27-32 °C). The vortex tube technology converts filtered compressed air into a low pressure, refrigerated air stream distributed throughout the enclosure. It also provides a light positive purge to seal out contaminants.
www.vortec.com
HONORABLE MENTION
Net-Access Overhead Cable Routing System - Panduit
It is a modular, 2 piece injection molded design that installs quick and easily to the top of the NET-ACCESS cabinet, eliminating need for other supporting infrastructure. It provides a high capacity data cable pathway directly over the cabinet.
www.panduit.com
Ethernet Hardware, GeneralCompact Link Selector
B&R Industrial Automation
Compact Link Selector from B&R connects Ethernet Powerlink controlled nodes, adding cable redundancy and reliability in unlimited tree structures. Process control and manufacturing automation often require cable redundancy and long cable runs, but closing a ring can cause cable feedback. Ethernet Powerlink protocol and double cabling can be made into unlimited tree structures, permitting data transfer via the highest quality network lines. The 62.5 mm wide Compact Link Selector module is operated as stand-alone unit, enabling as many Powerlink devices as needed on one network with cable redundancy. The link selector function is integrated in the X20 bus controller BC8884 for connecting an X20 System.
www.br-automation.com
HONORABLE MENTION
EK1501 and EK1521 - Beckhoff Automation
Fiber-optic EtherCAT Coupler and junction terminal for EtherCAT I/O networks enable extremely long distance networking up to 2 km (1.24 miles) with 100BASE-FX. The EtherCAT I/O Terminal system from Beckhoff supports all common wiring topology methodologies: line, ring, tree, and star.
www.beckhoffautomation.com
Ethernet SwitchesStratix 8000 Switches
Rockwell Automation
Rockwell Automation and Cisco collaborated on new industrial managed switches to address network convergence activities in manufacturing and IT organizations today. This convergence of technologies provides opportunities to reduce risks and costs, provide secure access to information, and improve agility and overall business performance. The new series uses Cisco Catalyst switch architecture and features, along with established configuration tools familiar to IT professionals. The switch can be configured using Allen-Bradley RSLogix 5000 programming software, automatically generates Logix tags for integrated diagnostics and includes FactoryTalk View faceplates for status monitoring and alarming.
www.rockwellautomation.com
HONORABLE MENTION
750-871 Ethernet TCP/IP Programmable Fieldbus Controller - Wago Corp.
Integrated Ethernet switch functionality enables 750-871 Ethernet TCP/IP 2-Port Programmable Fieldbus Controller to optimize networking capabilities while streamlining associated costs.
www.wago.us
I/O Systems
Snap I/O for Allen-Bradley Systems
Opto 22
Snap I/O for Rockwell Automation/Allen-Bradley systems provides advanced I/O options and functionality—including distributed control capabilities—when building, modifying, or expanding A-B automation architectures. Opto 22 has assisted engineers who build or work in this environment by introducing Snap I/O for Allen-Bradley systems, to offer advanced distributed control functions for PLC-based systems, including PID loop control, high-speed counting and latching, quadrature counting, pulsing, thermocouple linearization, analog scaling, time-proportional output, and others. Snap I/O for A-B systems communicates using EtherNet/IP, the same protocol used by A-B PLCs, such as ControlLogix and CompactLogix. www.io4ab.com
HONORABLE MENTION
IP67 Ethernet I/O Module - Molex
It controls simple input and output devices via industrial Ethernet networks and is said to be the most advanced and useful harsh environment I/O block. It communicates via three industrial Ethernet protocols. An integrated switch makes cabling easier. It has an M12 quick disconnect on each port; an LED scrolling display show errors and more.
www.molex.com
Network Hardware, GeneralVersacard PCIe
Molex
An intelligent network interface card that can communicate on up to 25 disparate industrial networks simultaneously over a PCIe backplane. Versacard PCIe is the first intelligent multi-protocol implementation in the industry. The Versacard PCIe is also the only card to support new PCIe technology for most of those networks, enabling new computer system adoption. The Versacard has a common API to all protocols which saves development time. And, the Versacard PCIe advanced diagnostics and data server software enable commissioning savings.
www.molex.com
HONORABLE MENTION
SeaLink USB Serial Adapters - Sealevel Systems Inc
SeaLink software-configurable USB serial adapters offer 1, 2, 4, and 8 serial ports that are individually software configurable for RS-232, RS-422, or RS-485.
www.sealevel.com
Signal Conditioning or DiagnosticsminiMoore
Moore Industries
With instrumentation, panel space equals money, so these new miniMoore analog signal conditioners offer large features in a small package. The miniMoore delivers up to
four low-cost input/output (I/O) channels in a 1 in. (25.4 mm) footprint, which equates to 0.25 in. (6.35 mm) per channel. Providing 1,000 V rms input-to-output and channel-to-channel signal isolation, the products can isolate, convert, boost and split analog signals inside rugged industrial metal housings, providing superior protection against unpredictable and harmful effects of RFI and EMI interference common in most industrial environments. Both 2- and 4-channel models provide isolated 4-20 mA outputs ready for interface with an indicator, recorder, DCS, PLC or PC-based SCADA system.
www.miinet.com
HONORABLE MENTION
EtherStax Analog Input Modules - Acromag
Units accept 32 differential dc current or voltage inputs and interface the signals to monitoring or control devices with Ethernet Modbus TCP/IP or UDP/IP communication.
www.acromag.com
Wireless, GeneralIon Wireless Security
Apprion Inc.
Layered security architecture for industrial environments to secure wireless networks and proactive security scans to detect and deter system attacks that could lead to system downtime and the introduction of erroneous information. The Ion Wireless Security application enables security policies at each layer for a secure wireless network: user authentication with secure role-based access, continuous proactive network monitoring for network vulnerabilities and rogue devices, and wireless network intrusion detection. The Ion application enables an open, technology agnostic approach to industrial wireless. This is critical for industrial wireless installations that employ multiple technologies, as all installations eventually will.
www.apprion.com
HONORABLE MENTION
ConnectPort X4 NEMA - Digi International
The ConnectPort X4 NEMA is an industrial–grade gateway that provides ZigBee to cellular (GSM) connectivity and is integrated into a NEMA 4X/IP66 enclosure for harsh weather conditions.
www.digi.com
Wireless, IEEE 802.11ILX34-AENWG
ProSoft Technology
Wireless 802.11g I/O adapter ILX34-AENWG is a high-speed, standards-based wireless I/O module that supports integrated wireless architecture and familiar programming with the EtherNet/IP protocol. ProSoft says the adapter fully supports its Integrated Wireless Architecture. It also provides a familiar programming experience to users by utilizing the EtherNet/IP protocol and allowing configuration with RSLogix 5000. The device employs 802.11i WPA2 with AES Encryption for security. Common applications are said to include packaging, material handling, oil and gas, and other remote or moving distributed I/O applications. www.prosoft-technology.com
HONORABLE MENTION
MatchPort b/g Pro - Lantronix
Secure WiFi for any electronic device: Embedded module, an application-ready device server, provides 802.11 b/g wireless connectivity for devices with a microcontroller serial interface.
www.lantronix.com
