Biobased/biodegradable coatings system
The biobased and biodegradable System replaces harzardous synthetic chemicals with safe, green alternatives for corrosion protection in metalworking industries.
The biobased and biodegradable System replaces harzardous synthetic chemicals with safe, green alternatives for corrosion protection in metalworking industries. BioCorr is water-based and designed for preservation of metals by combining film-forming additives with Vapor phase Corrosion Inhibitors (VpCIs). Ecoline 3220 is a conola-oil based, temporary coating that clings to metal surfaces for vapor corrosion inhibition and lubrication. Ecoline 3690 is an open-air solution for marine and high humidity conditions and has no effect on rubber, plastics, or paint. Ecoline Cleaner/Degreaser is a soya based solution designed for tough cleaning jobs and can be used on all metals and alloys. The cleaner is non-flammable, and all the products in the system are VOC, chromates, and nitrites free.
Cortec Corporation
