The Model 700 industrial waste ejector pump is designed for use in industrial, sanitary process, and rendering wastes.
The Model 700 industrial vertical non-clog waste ejector pump is designed for use in industrial, sanitary process, and rendering wastes. The Model 700 features heads to 100 feet total dynamic head (TDH) and flows to 1,500 gallons per minute. The impeller is an enclosed two vane non-clog design with wiping vanes which reduce axial loading and prolong bearing life. Wiping vanes aid in keeping particles from behind the impeller and pump bearing assembly. There is a flanged discharge on all sizes. Designed specifically for solids handling, the 700 Series incorporates a long radius elbow, reducing friction loss and allowing smooth flow through the discharge pipe.
Vertiflo Pump Company
