This line of small form factor USB-based data acquisition and control I/O modules features a high-speed USB 2.0, multifunction board with 16 channels of 16-bit resolution analog outputs along with two 16-bit analog inputs and 16 digital I/O lines packaged in a small, rugged, industrial enclosure.
The boards feature both unipolar and bipolar outputs.Additional specific ranges can be achieved as factory options. All analogoutput channels can be updated either individually or simultaneously. Systemcalibration specific to user requirements can be performed via a provided,easy-to-use, software utility. Automatic circuits limit analog outputs to 0 Vuntil initialized via software command.
A micro-USB header connector is provided in parallel withthe high retention Type B connector and can be used for stacking and embeddedapplications. Available accessories include a wide variety of cables and screwterminal boards for quick and easy connectivity.
Key features of the USB-AO series include:
- Up to 16 analog outputs with 12- or 16-bitresolution
- High-speed USB 2.0 device, USB 1.1 compatible
- Unipolar and bipolar output ranges
- Real-time hardware calibration per channel
- Update outputs individually or simultaneously
- Two 16-bit analog inputs and 16 lines of digitalI/O
- All digital I/O lines buffered with 10 mAsource, 24 mA sink current capabilities
- USB/104 form-factor for OEM embeddedapplications
- OEM version (board only) features PC/104 modulesize and mounting compatibility
- Alternate micro-fit embedded USB headerconnector
- Type B USB connector features industrialstrength and high-retention design
- Extended operating temperature and DIN railmounting provisions
- Eight or four channel versions available.
- View data sheet andmanual for the USB-AO here .
ACCES I/O ProductsInc.
www.accesio.com
