CBI all-in-one UPS power solutions combines multiple functions in a single device for use as a power supply unit, battery charger, battery care module, or backup module.
CBI all-in-one UPS power solutions combines multiple functions in a single device for use as a power supply unit, battery charger, battery care module, or backup module. This device is compatible with a range of common battery types and is equipped with a real-time diagnostics system to continuously monitor battery status, charging levels, and potentially emerging battery faults. The CBI device ultimately will suit any battery-power application in any industry or setting where battery reliability is essential and the availability of backup power is critical.The CBI is available in 12, 24, and 48VDC output versions and can perform over a wide temperature range from -40 to 70ºC (-40 to 158ºF) and is housed in a compact and rugged metal case offered in three sizes.
Altech Corp.
