Multi-mode UPS
The G8000MM multi-module three-phase UPS system expansion or reduction can be done without UPS modification. The 100-750 kVA modules provide the scalability of using up to eight UPSs in parallel for a maximum of 6,000 kVA. Features include input power-factor correction, IGBT charger and inverter, 0.9 output power factor and three-year factory warranty on parallel UPS systems.
The G8000MM multi-module three-phase UPS system expansion or reduction can be done without UPS modification. The 100-750 kVA modules provide the scalability of using up to eight UPSs in parallel for a maximum of 6,000 kVA. Features include input power-factor correction, IGBT charger and inverter, 0.9 output power factor and three-year factory warranty on parallel UPS systems. Other features include online double conversion technology, a dual-input design and a static bypass switch.
Toshiba International : www.toshiba.com/ind
Plant Engineering Staff
