Molykote L-0501 high-performance lubricant is a multi-purpose penetrating oil formulated to loosen rusted parts, stop squeaks and provide corrosion resistance and long-term lubrication.
Molykote L-0501 high-performance lubricant is a multi-purpose penetrating oil formulated to loosen rusted parts, stop squeaks and provide corrosion resistance and long-term lubrication. The lubricant is designed for applications such as locks, hinges, cranks, sliding doors, tools, chains, cables, switch linkages, knuckles, pins and pivots. It is available in liquid and aerosol formulations featuring a no-clog spray, and contains an anti-wear additive.
Dow Corning
www.molykote.com
