The High Bay LED fixture is manufactured from a solid piece of anodized, extruded aluminum that includes ribbed fins at the top to further increase surface area.
The High Bay LED fixture is manufactured from a solid piece of anodized, extruded aluminum that includes ribbed fins at the top to further increase surface area. The design allows the entire structure to act as a heat sink, moving heat away from the fixture and, most importantly, the LEDs. Because of its ability to dissipate heat, the fixture comes with a seven-year warranty for all parts, including the power supplies, surpassing typical offerings ranging from three to five years. A tray change allows light distribution from 55 degrees to 85 degrees or 105 degrees. It is predicted to maintain 70% of its initial light output for up to 150,000 hours, surpassing the 100,000-hour ratings of competitive fixtures. The LEDs also boast efficiency of 110 lumens per watt.
Big Ass Fans
