Super Grease is an NLGI #2, high-temperature range product that does not separate, run, or fall out. The product has high load-bearing properties and excellent mechanical stability when sudden temperature changes occur. Operating range is -65-650 F.
Super Grease is an NLGI #2, high-temperature range product that does not separate, run, or fall out. The product has high load-bearing properties and excellent mechanical stability when sudden temperature changes occur. Operating range is -65-650 F.Slide Products, Inc., www.slideproducts.com
Circle 395
