Door controller
The Matrix System Gateway is an intelligent Ethernet-to-485 converter/switch that automatically maintains connections between the system’s third-tier intelligent door controllers and second-tier building controller.
The Matrix System Gateway is an intelligent Ethernet-to-485 converter/switch that automatically maintains connections between the system’s third-tier intelligent door controllers and second-tier building controller. The gateway’s unattended fail-over capability reroutes all communication to an alternate controller, allowing the system to maintain all high-level access functions despite key component failure. Other fault-tolerance options include installation on separate network segments and the ability to allow building controllers to be shut down in a hot-swap mode for maintenance without affecting the access control system. It also automatically propagates data across the system from the server to the intelligent building controllers.
Matrix Systems
www.matrixsys.com
Plant Engineering Staff
