Cycling air dryers
The refrigerated dryer series is now available for flows from 20 to 885 scfm, in pressures up to 230 psig. The cycling dryers provide efficiency by using a thermal mass medium for storage and operating the refrigerant compressor only when necessary. An air-to-air heat exchanger reduces the load on the refrigeration system by pre-cooling the inlet air. The dryer design facilitates access to all components and minimizes the required floor space. Standard features include simple controls, a stainless-steel separator and an electric demand drain.
Kaeser Compressors www.kaeser.com/cleanair
Plant Engineering Staff
