Emerson Process Management's Micro Motion F100P and HPC010P Coriolis flowmeters are designed to measure accurate flow rates for wellbore chemicals injected at high pressure conditions for demanding offshore applications.
Emerson Process Management’s Micro Motion F100P and HPC010P Coriolis flowmeters are designed to measure accurate flow rates for wellbore chemicals injected at high pressure conditions. Both meters are designed to allow operators to monitor chemical injection to ensure long term asset reliability and flow assurance for demanding offshore applications. The F100P is a 1-in. meter with a maximum pressure rating of 6250 psi that targets measurement for higher flow rates typical for hydrate inhibitors. The HPC010P has a maximum operating pressure of 15,000 psi to address offshore chemical injection measurement for chemicals such as corrosion, scale and asphaltene inhibitors.
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
