Waveform generators
Fluke Corporation introduces the 29x series of 100 MS/s universal waveform generators that produce multiple signals to test complex electronic circuits. The generators feature 1M point waveform memory and unlimited waveform storage using removable Compact Flash memory cards. The 29x series uses direct digital synthesis technology with variable clock sampling to provide full-featured programmabi...
Fluke Corporation introduces the 29x series of 100 MS/s universal waveform generators that produce multiple signals to test complex electronic circuits. The generators feature 1M point waveform memory and unlimited waveform storage using removable Compact Flash memory cards. The 29x series uses direct digital synthesis technology with variable clock sampling to provide full-featured programmability and accurate arbitrary waveform generation. The series includes the Model 291 single-channel, Model 292 two-channel, and Model 294 four-channel generators. The Fluke 29x series is part of Fluke’s complete range of signal source generators designed for low frequency (50 MHz or lower) audio manufacturing and service applications.
Fluke Corporation
www.fluke.com
