Two-stage stationary air compressors
Electric two-stage, vertical-tank stationary air compressors provide 175 PSI and displace between 9.1 and 43.6 cfm. With 16 models available, each compressor is equipped with a two-stage cast-iron pump and a powder-coated, ASME-certified tank. A large flywheel accommodates extra cooling; a directional air shroud helps reduce pump temperatures; and a thermal-overload protection feature prevents ...
Electric two-stage, vertical-tank stationary air compressors provide 175 PSI and displace between 9.1 and 43.6 cfm. With 16 models available, each compressor is equipped with a two-stage cast-iron pump and a powder-coated, ASME-certified tank. A large flywheel accommodates extra cooling; a directional air shroud helps reduce pump temperatures; and a thermal-overload protection feature prevents the motor from drawing too much current and overheating. The compressors are powered by either a one-phase or a three-phase electric motor, providing between 2 and 10 hp. Tank sizes include 60, 80 and 120 gallons.
Jenny Products Inc.
www.jennyproductsinc.com
Plant Engineering
Plant Engineering Staff
