Top 10 ways to protect your VFD investment
Variable speed drives offer savings, if used properly provide better motor control to operate the system at lower speeds and unity power factor. But how can you protect that big investment?
  • Discover 10 ways you can protect your variable frequency drive investment.
  • Learn how selecting the proper VFD will make a huge difference in the drive’s usefulness.
  • Determine how VFDs are worth the investment for your plant’s systems.
VFD insights
  • A variable frequency drive (VFD) can save money by providing motor control to operate the system at lower speeds.
  • Investing in these drives is costly, but there are certain things users can do to maximize and optimize their investment.
  • Ten best practices can ensure users maximize those benefits.
Manufacturers improve efficiency using variable frequency drives (VFDs) for electrical motors. Compared to across the line starters or older dc drives, variable ac drives can save users money by providing better motor control to operate the system at lower speeds and unity power factor. Over time, the payback from these savings reduces operating costs and provides a return on investment. However, this is only possible by ensuring the lifecycle of these units are maximized and optimized.
Decentralized VFD mounted next to motor. Courtesy: Siemens
Ten ways to protect your VFD investment
1. Know your application.
Protecting your VFD investment begins prior to the actual purchase. Factors such as performance, speed or torque control, fieldbus communications or even inputs and outputs can often affect the model of unit you will need. Taking the time to first determine actual needs before the purchase can often differentiate between a successful project and one that keeps maintenance personnel up in the middle of the night.
2. Engineer the system properly.
The VFD needs to be sized according to load and ambient conditions to ensure that it can handle the torque required in all situations. Be sure to consult with the VFD manufacturer, which will have design resources available for support.
3. Evaluate at your environment.
If it is contaminated with dust, conductive residue, debris, moisture, oil, high temperatures or other potential disruptors, investing in a VFD rated NEMA 12 or NEMA 4 could protect it from these variables. Also consider temperature, altitude and humidity and compare them to the manufacturer’s specifications. The electrical environment is also important and often overlooked. Existing harmonics, stray voltages, imbalances or line spikes can cause adverse effects to your new installation. Filters, reactors and isolation transformers are other items that may be needed to ensure a properly operating environment.
4. Select the correct motor.
Not all motors are created equal. Due to the nature of the pulse-width modulation (PWM) waveform that a VFD generates to produce a synthetic ac waveform, there are often high voltage spikes. VFD-rated motors are equipped with extra insulation and are designed to handle this. Be sure to consult with the motor manufacturer regarding speeds, duty cycle, isolated bearings, ground brushes and environment. A good motor manufacturer will work to verify you are purchasing the best product for the application.
5. Specify the correct fusing, cabling and filters.
Before finalizing the installation, be sure to consult the installation manuals which come with the VFD. They provide valuable information regarding compliant fuses and cables sizes and types (such as VFD cable), as well as any external items you may need such as a load reactor to prevent things like reflective waves. Further, use the correct wiring and wiring practices during the installation process. A VFD cannot maintain its NEMA 12 or NEMA 4 rating if wiring practices and components of the same rating are not used.
6. Use trained and qualified professionals to install the equipment especially in harsh environments.
Manufacturers provide minimal standards for installation and often there are local electrical regulations which also need to be met. Further, a trained and qualified installer will be able to ensure that drives are mounted correctly, all wiring is bonded and grounded properly, the installation allows for proper airflow, and all covers and protective barriers have been reinstalled correctly.
7. Verify that those doing the start-up and commissioning are well-versed in VFD operation.
Knowing and understanding how to properly enter the motor data, utilize PID controls, and establish field bus communications will help assure that you meet both budgets and deadlines during the installation.
8. Invest in training.
Having a good working comprehension of variable AC drives will help you and maintenance staff to better understand what is considered normal and abnormal operation. By identifying abnormalities early, you could prevent unexpected failures and downtime and be able to better help troubleshoot when the unexpected does occur.
9. Perform regular maintenance.
Like most electrical equipment, VFD manufacturers prescribe recommended maintenance intervals which should be followed. This will allow you to planned shutdown times to clean and inspect your unit, identify potential problems, and remove any items which may be preventing your equipment from properly dissipating heat. Also it allows you to chart standard operating conditions and identify if things are starting to break down, such as your electrolytic capacitors.
10. Invest in recommended spare parts and review them on a regular basis.
It is one thing to purchase a spare unit, and another to use it. Many VFDs today have electrolytic capacitors, which, if left unused for more than a year, begin to deteriorate. This may cause the unused drive to spontaneously combust when finally installed. While it is important to have extra parts like fuses and control boards, as well as spare VFDs, on hand, it is just as important to regularly test and inspect them to ensure they are in good operating condition and ready for use.
It’s important to realize that anyone can purchase a VFD and install it; however, it is imperative that the installation process be followed precisely. By spending the necessary time up front, investing in the correct products for your application, and by conducting regular maintenance, you will reap the energy savings and operational efficiencies of a VFD for many years to come.
Jon Mosterd
Jon Mosterd is engineering manager, North America Center of Excellence, Danfoss Drives.
