Synchronous motors
The 8LT Series three-phase synchronous motors are virtually maintenance-free and help eliminate the need for angular gears. The synchronous motors are available in two sizes with self-cooled and externally cooled options. The supply voltage of the high-torque motors ranges from 400-480 Vac, with a rated power of 0.
The 8LT Series three-phase synchronous motors are virtually maintenance-free and help eliminate the need for angular gears. The synchronous motors are available in two sizes with self-cooled and externally cooled options. The supply voltage of the high-torque motors ranges from 400-480 Vac, with a rated power of 0.11-21 kW. The synchronous motors feature an embedded parameter chip that identifies device data such as serial number, manufacturer data and type.
B&R Industrial Automation Corp.
www.br-automation.com
Plant Engineering
Plant Engineering Staff
Since 1947, plant engineers, plant managers, maintenance supervisors and manufacturing leaders have turned to Plant Engineering for the information they needed to run their plants smarter, safer, faster and better. Plant Engineeringā€˜s editors stay on top of the latest trends in manufacturing at every corner of the plant floor. The major content areas include electrical engineering, mechanical engineering, automation engineering and maintenance and management.
