Calculating a lubricantās carbon footprint is not simple. Producing meaningful results requires adequate data, harmonized methodologies and stakeholder collaboration.
- Understand how companies are trying to make their products more sustainable and efficient.
- Learn how lubrication companies are reducing their carbon footprint and the challenges and pitfalls they face.
Lubrication insights
- Carbon footprint calculations that can be compared across products and manufacturers require agreement on definitions and methodologies, documentation and validation.
- Limited data availability and wide variations in feedstocks and product types introduce complications into carbon footprint calculations.
- Achieving a meaningful global standard requires global cooperation and alignment along all parts of the value chain.
Responding to climate change requires everyoneās participation, including the lubricant industry. However, a transformation in our industrial society is needed if we are to reduce greenhouse gas emissions and other pollutants in a significant way. In order to build sustainable industrial practices, we need to understand the main factors influencing climate change. Here, we focus on quantifying carbon dioxide (CO2) and carbon footprints as a necessary metric for setting goals and measuring progress.
This article is based on an STLE webinar titled Sustainability in the Value Chain of Lubricants – Challenges and Pitfalls, presented by STLE member Inga Herrmann, head of the lubricant department of Verband Schmierstoff-Industrie e.V. (German Lubricant Manufacturers Association).
Today, we use fossil materials (e.g., coal, petroleum and natural gas) on a large scale to provide energy and as sources of carbon for many chemical processes. If we switch from fossil carbon sources to renewable energies, we reduce or eliminate climate- changing carbon and CO2 emissions, but industry loses carbon as a source for many raw materials. Our challenge now is to obtain the carbon needed for products and processes from sustainable sources to create a true carbon cycle.
Creating sustainability on a large scale will likely require a combination of several approaches (see Figure 1). Recycled carbon-containing materials and biomass are two potential alternative sources of carbon. Another potential source is air capture, in which CO2 is taken from the atmosphere and is converted into high-value chemical products.
Increasingly, governments and international organizations are establishing targets and measuring progress toward two goals: climate neutrality and decarbonization. Lubricant manufacturers are feeling the effects along the entire length of their supply chains. Suppliers are changing their raw materials and processes by substituting biological and sustainable components for fossil carbon sources, which also influences the products and processes of the lubricant marketers. Customers andĀ original equipment manufacturers (OEMs) increasingly ask for climate-neutral and decarbonized products as well. Whatās more, the capital market now prioritizes investing only in companies that implement sustainability goals. Thus, measuring and managing the lubricant industryās carbon footprint becomes critical to reducing CO2 emissions.
When companies begin their sustainability efforts, they often carry out sustainability metrics to define time-critical fields of action and to find ways of working together with their colleagues upstream and downstream in the supply chain. Collaboration along the length of various supply chains is key to success in large-scale, long-term sustainability efforts, as outlined in the U.N.ās 17 Sustainability Goals.
Feedprints, footprints, handprints and other terminology
Calculating a corporationās carbon footprint begins with examining operations from factory gate to factory gate for each of the corporationās worldwide locations and subsidiaries. It also requires identifying boundaries between the steps in the production, use and disposal chain for each product.
The Greenhouse Gas Protocol Corporate Standard for calculating a corporate carbon footprint is equivalent to the ISO 14064 standard, and it encompasses three scopes. Scope 1 involves carbon emitted directly as a result of running machinery, driving vehicles, heating buildings and other onsite operations. Scope 2 covers indirect (offsite) emissions created during the production of energy that an organization buys. Scope 3 emissions, which often account for more than 70% of a companyās footprint, are produced by suppliers that make products that the company uses or as a result of customers using products that the company sells.
Extraction and production of raw materials constitutes the ācradleā that starts a supply chain, and the resulting carbon emissions are referred to as the āfeedprintā (see Figure 2). The lubricant manufacturer buys these raw materials or lubricant components made from these materials and brings them into the factory (the first āgateā in a gate-to-gate calculation). The manufacturer then makes finished lubricant products that it sells to its customers (the second āgateā). The carbon emissions involved in getting this product to the point of sale is the companyās carbon āfootprint.ā A cradle-to-gate calculation uses the total of the feedprint, the footprint and the utilities used in making the finished lubricant.
The lubricant manufacturer can evaluate the products it sells using benchmarks that represent a typical life cycle analysis, but ultimately, the customer is responsible for selecting and applying their lubricants. Customers buy finished lubricant products, which they use to reduce friction, wear and corrosion in their machinery. They look for products that lengthen oil drain intervals and reduce evaporation losses. Each of these factors reduces the lubricantās āhandprint.ā
The point where a customer disposes a used lubricant is the āgraveā in a cradle-to-grave calculation. Increasingly, however, stakeholders in the lubricants industry and their customers and suppliers are advocating for a ācircular economyā approach. Once a lubricant reaches the end of its service life, it can be collected and regenerated or reprocessed into new base oils or feedstocks for the production of new lubricantsāa cradle-to-cradle approach. This approach produces significant, measurable reductions in CO2 emissions to the atmosphere compared to virgin base oils or conventional base oils. Some waste oils with a high additive content cannot be regenerated, but they can be incinerated to generate heat rather than being discarded.
Many lubrication sources in the upstream chain
In the lubricant manufacturing industry, the upstream chain is the starting point in calculating the carbon footprint of a finished lubricant (see Figure 3). About 90% of CO2 emissions in this industry come from the raw materials: base oils and additives. Base oils are produced from crude oils that originate from all over the world and take various modes of transportation to arrive at the lubricant factoryās gate. Heavy crude comes from Venezuela, high-flare crude from the Middle East and crude with high methane slip (methane released into the atmosphere) from Siberia. Carbon footprint estimates for crude oil can vary by a factor of more than 600%.
For the purposes of carbon footprint calculations, one approach is to exclude extreme CO2 emitters such as oil sands if they are not relevant for base oil production, and to take an average of the remaining sources. Because there is no standard for crude oil, a global average parameter can be determined for each single base oil type using these average values. However, a realistic carbon footprint quantification requires considering the uncertainties introduced by the large range of estimated values and building a safety margin into any decisions derived from these results.
The same principle applies to transportation of base oils from different parts of the world by ships, pipelines and other means, because carbon footprint contributions from these methods of transportation can vary by more than 250%. To determine a specific base oil figure or a specific carbon footprint of a single base oil type per refinery, we need to calculate a realistic average value based on the mass flow (more on this later) and adding the utilities and the energy involved.
The high degrees of variability in base oil production and transportation demonstrate how uncertain the database is and how time consuming it would be to generate reliable data for each situation. The situation for additives is even more complicated. Most additive suppliers are chemical companies with highly complex and diverse processes and products.
For example, the same molecule can be produced from different sources or by different processes. Further, suppliers themselves decide on processes and products. They decide on and prioritize which sustainability criteria they will apply, and this in turn influences the lubricantās value chain and the lubricantās processes. The secrecy of the additive supplierās intellectual property plays a central role, and this makes a detailed calculation and providing of individual data much more complicated.
This combination of feedstock variability and incomplete information greatly complicates the search for the right methodology of calculating a product carbon footprint of a finished lubricant.
Challenges and pitfalls of calculating carbon footprints
Lubricants often have a complex value chain, and it is essential to cover all relevant requirements of this value chain when setting up a calculation scheme and transforming this into a pragmatic approach. This effort requires cooperation and collaboration among all stakeholders across the value chain.
Industries in general are beginning to collect the necessary primary data, but these data are often not available for lubricant components. Because itās very difficult to get specific values for crude oil or base oil, we need to work with proxy data or with estimates for the time being and to work on getting reliable primary data to generate more accurate carbon footprints in the future.
The lack of a common methodology and standard values makes it difficult to calculate the product carbon footprint of a finished lubricant along the whole value chain and to compare results for various products. Many companies are starting to provide data, but there is no transparency on which standards or methods have been used to calculate and verify those data. How do they arrive at these data, and how do you make sure that you can compare them? Data verification is essential to ensure that data are objective, reliable, transparent and comparable.
Global standards already in place, like the greenhouse gas protocol or the ISO standards, are not very specific, and they offer a great scope of interpretation. These standards can set the frame, but they cannot reflect the specific characteristics of a lubricantās value chain. Also, they are not applicable specifically for finished lubricants because they apply to all products in different industry segments.
The transition to more sustainable lubricants requires comparing the carbon footprints of various products. This requires a common, consistent methodology, with information provided at appropriate intervals to help track performance (see Figure 4). Developing such a methodology for carbon footprint calculations for finished lubricants involves addressing several issues.
Boundaries, allocations and hierarchies
One important issue is the definition of the system boundary. Currently, methodologies exist that cover the cradle-to-grave approachāfrom the productās feedprint to end of lifeāwhich requires constructing a description of the productās life cycle. However, lubricant materials and components are often sold as intermediates, which requires a cradle-to-gate approach. This requires establishing boundaries that define where the gates are and what constitutes the productās end of life. Clearly defined boundaries prevent double counting of CO2 emission reductions from, say, a lubricant manufacturer and the OEM they supply.
The cradle-to-gate approach only considers the emission reductions associated with the lubricant manufacturerās processes, and not the potentially much greater contributions that these lubricants make to emission reductions resulting from the customerās use of the lubricants. Because the lubricant manufacturer does not dictate how the customer uses the product, they cannot claim the credit for these emission reductions. A lubricant manufacturer can make recommendations to their customers on how to use their products in the most sustainable way, but ultimately the end-user bears the responsibility for their application of the product. Thus, the manufacturerās contribution to the carbon footprint essentially ends when the product leaves the factory gate.
Another relevant aspect is the allocation procedure. Allocation approaches divide energy and emissions burdens among co-products based on their mass, energy or market value shares. Lubricants are non-energy products (i.e., they are not used as sources of energy), so physical allocation on a mass basis is preferred. If another allocation approach is applied, it must be clearly documented according to the ISO hierarchy described in their 14040, 14044 and 14067 standards.
A third aspect is a hierarchical approach to data sources. Primary data is the best option where itās available, but primary data are often site-specific, or they come from different representative product systems, so itās very difficult to align primary data from different sources. Secondary data (proxies, estimates and processes under investigation) require a conservative approach that recognizes the greater margin of uncertainty. As more and more reliable and realistic primary data become available, calculations can be revised to reflect a greater degree of precision.
Compensatory factors (reductions in carbon footprint that counterbalance some fraction of the carbon emissions produced by a process) also come into play. However, including these factors requires doing your homework to ensure that the claimed benefits are based on real improvements rather than āgreenwashingāāglossing over environmentally unsound practices or using vague, unverifiable terms like āclimate neutral,ā āecofriendlyā or āsustainable.ā For example, avoiding greenhouse gas emissions should be prioritized over offsetting emissions. Reducing emissions from your own processes and close to your own product chain or related region should be the highest priority. Once these improvements have been made, then compensating factors can be considered, but only then.
How the lubricant industry can calculate its carbon footprint
If the lubricant industry is to calculate a meaningful carbon footprint, there must be a harmonized, agreed-upon industry approach that is aligned through all stakeholders of the value chain (see Figure 5). The approach should begin by building upon international standards before going into details.
Itās very important to apply the complex, specific requirements of the lubricant industry within this methodology and to establish consistent guidelines on boundaries (cradle-to-gate or cradle-to-grave).
The allocation mode should be defined so that the preference is for physical allocation on a mass basis for non-energy products, with documentation required for other allocation methods. Primary data must be first in the hierarchy of data sources. If there are no primary data available, secondary data may be used with a sufficient safety margin.
Independent assurance and verification are important. The best methodology is worthless without a neutral, independent monitor to ensure that the calculations follow rules of the stated methodology. Itās also important to create a level playing field by establishing a neutral, precompetitive platform for the data on which carbon footprint calculations are based and evaluated and to ensure that everyone has the same access to these data.
No single company can accomplish this as a solo effort. Achieving a meaningful global standard requires global cooperation and alignment along all parts of the value chain. Acceptance of a methodology across the board requires interaction and harmonization among partners, suppliers, OEMs and customers, as well as legal authorities and non-governmental organizations (NGOs). The payoff is that establishing a common basis for calculating carbon footprints enables better decisions for the energy transition.
At present, there is no established harmonized methodology for calculating a product carbon footprint, in part because of the difficulty that intellectual property protection presents to gathering data. However, various collaborative efforts are making progress on methodologies for specific products.
For example, Europeās Together for Sustainability initiative, an industrial consortium driven by the chemical industry, recently launched an open-source guideline for chemical product carbon footprint calculations. Catena-X, an auto industry group, is working to enable the digital flow of open, secure data across the entire automotive supply chain. The World Business Council for Sustainable Development is coordinating with other carbon footprint efforts to address the quality and comparability of emissions data and to set consistent rules across various industry sectors for calculating and reporting product carbon footprints. These are just three examples of organizations around the world who are working to tackle this challenge.
Many individual companies have already begun their own sustainability journeys. In addition, they have joined collaborative efforts with other companies and organizations, in recognition of the interdependency among companies along the supply chain on the quality of each otherās data.
Reprinted with permission from the December 2023 issue of TLT, the official monthly magazine of the Society of Tribologists and Lubrication Engineers, a CFE Media and Technology content partner.
REFERENCES
https://sdgs.un.org/goals
https://ghgprotocol.org/corporate-standard
https://webstore.ansi.org/standards/iso/iso14064greenhousegasespackage
www.weforum.org/agenda/2022/09/scope-emissions-climate-greenhouse-business/
www.pembina.org/blog/real-ghg-trend-oilsands
https://nap.nationalacademies.org/read/25232/chapter/10#171
https://pre-sustainability.com/articles/lca-standards-and-guidelines/
www.tfs-initiative.com/
https://catena-x.net/en
www.wbcsd.org/
https://cen.acs.org/business/informatics/quest-data-products-carbon-footprint/100/i40
