Lighting power packs
The BZ-50 and BZ-150 high-output, universal-voltage, plenum-rated, RoHS-compliant power packs use zero-crossing to switch line voltage loads and provide 24 Vdc to power occupancy sensors or other devices.
The BZ-50 and BZ-150 high-output, universal-voltage, plenum-rated, RoHS-compliant power packs provide design flexibility as well as increased energy savings potential. The power packs use zero-crossing to switch line voltage loads and provide 24 Vdc to power occupancy sensors or other devices. The BZ-150 can be field-configured for manual-on operation to support either a manual-on or bi-level automatic-on control strategy. Both power packs accept 120-, 230- or 277-V power at 50 or 60 Hz and provide a 225 mA output.
Watt Stopper/Legrand
www.wattstopper.com
Plant Engineering
Plant Engineering Staff
