Laser alignment system
OPTALIGN smart is a laser shaft/coupling-alignment system designed for use in maintenance work and rotating equipment. It features automatic continuous measurement as the shaft is rotated, automatic evaluation of alignment condition, soft foot check, a backlit TFT screen, a static measurement mode and an alignment reporter.
OPTALIGN smart is a laser shaft/coupling-alignment system designed for use in maintenance work and rotating equipment. It features automatic continuous measurement as the shaft is rotated, automatic evaluation of alignment condition, soft foot check, a backlit TFT screen, a static measurement mode and an alignment reporter. Multipoint mode measurement works at any three or more positions of more than 70 degrees rotation.
LUDECA Inc. : www.ludeca.com
Plant Engineering
Plant Engineering Staff
