Heaters
The PRH series of plenum-rated heaters is designed for concealed and plenum space applications such as those found in bathrooms and in suspended ceilings. The heaters offer a blow delay feature and multiple heat selections, with heating ratings from 3 to 15 kW. Maximum outlet air temperature is 200 F at a static pressure of 0.
The PRH series of plenum-rated heaters is designed for concealed and plenum space applications such as those found in bathrooms and in suspended ceilings. The heaters offer a blow delay feature and multiple heat selections, with heating ratings from 3 to 15 kW. Maximum outlet air temperature is 200 F at a static pressure of 0.2 inch. The heaters are available in 208-, 240-, 277- and 480-V versions and include a two-speed motor, external 24-V thermostat controls and a high-limit safety cutout.
Marley Engineered Products
www.marleymeh.com
Plant Engineering Staff
