Drain trap
The AMD 1550 removes condensate and contaminants from air systems while protecting equipment. An automatic magnetic drain, it offers working pressures of up to 230 psig and a discharge capacity of 53 gallons per hour. Installation is accomplished through top or bottom connections, and the unit’s modular construction facilitates maintenance.
The AMD 1550 removes condensate and contaminants from air systems while protecting equipment. An automatic magnetic drain, it offers working pressures of up to 230 psig and a discharge capacity of 53 gallons per hour. Installation is accomplished through top or bottom connections, and the unit’s modular construction facilitates maintenance. Designed for use with coolers, refrigerated dryers, separators, filters and liquid separators, the drain trap maintains a liquid seal to prevent the loss of compressed air.
Kaeser Compressors Inc.
www.kaeser.com
Plant Engineering Staff
