Configurable linear actuator
Single-Axis Actuators are available in 208 configured styles, are compatible with most servo motors and are designed to provide precision linear motion in general industrial assembly as well as automotive, packaging and medical manufacturing applications. Each unit has a ball-screw driven guided device; is built on an extruded 6063-T6 aluminum base with a black anodized finish and 1045 steel si...
Single-Axis Actuators are available in 208 configured styles, are compatible with most servo motors and are designed to provide precision linear motion in general industrial assembly as well as automotive, packaging and medical manufacturing applications. Each unit has a ball-screw driven guided device; is built on an extruded 6063-T6 aluminum base with a black anodized finish and 1045 steel side supports; and has a grooved base for sensor mounting. Units are manufactured 11 working days from order date.
Misumi USA Inc. : www.misumiusa.com
Plant Engineering
Plant Engineering Staff
