Belt drive slide
The ZF1 belt drive slide is a lightweight unit and is driven by a 9-mm-wide HTD belt that is available in travels ranging from 6 to 112.3 inches.
The ZF1 belt drive slide is a lightweight unit and is driven by a 9-mm-wide HTD belt that is available in travels ranging from 6 to 112.3 inches. Suitable for use in tight spaces, the belt drive slide is 30 mm wide, with an accompanying carriage measuring 72 mm wide. The carriage rides on two precision ground steel shafts that are supported the entire length of travel to minimize deflection, while the HTD belt profile helps to eliminate backlash. Techno Inc. www.techno-isel.com
Plant Engineering
Plant Engineering Staff
