Atomizing nozzles
Internal Mix Atomizing Spray Nozzles mix liquid and air inside the nozzle and produce the finest atomization of liquids up to 300 centipoise. T
The No Drip Internal Mix Atomizing Spray Nozzles work in the same way standard atomizing nozzles do, mixing liquid and air inside the nozzle and produce the finest atomization of liquids up to 300 centipoise, but have the added benefit of positively stopping liquid flow when compressed air is shut off.
Available in five patterns: narrow angle round pattern, wide angle round pattern, flat fan pattern, deflected flat fan pattern and 360° hollow circular pattern they are for pressure fed applications that don’t require independent air and liquid control. The nozzles are fully adjustable and have interchangeable liquid and air caps.
EXAIR Corporation
www.exair.com/ndintmix.htm
